Hi Diego,
The word "interrupt" is used to mean different things at different levels of description. In the asynDriver documentation (http://www.aps.anl.gov/epics/modules/soft/asyn/R4-22/asynDriver.html)
you'll find the quote 'Interrupt just means: "I have a new value." ' In the section of the EPICS Application Developer's Guide you mentioned, "interrupt" means "actual interrupt signal
from the hardware."
When an asyn client registers to receive interrupts, it's asking to be called when the driver has a new value, whether that value came from a hardware interrupt, or from the driver's polling of the hardware.
Tim Mooney
Hello everyone,
Reviewing EPICS Application Developer's Guide, I have noted some point in the figure contained in chapter 3, point 3.3 (IOC Software componentes) that let me a little bit confused. I am refering to the box "Driver or Device Interrupt Routines", that interconnects
directly the line (VME) with the box "scanners". I have implemented some Epics Device support for RIO/FlexRIO devices using AsynDriver, and the way I have implemented is using interrupt calls, that in the upper layer of the asynDriver, are epics device standard
docallback interrupts. This software layer I'll integrate in the box "Device Suport"... but then I don't know what the box "Driver or Device Interrupt Routines" refers to. Does It means that there is other ways in EPICS to implement pices of code that generate
interrupts on the EPICS Core? Could someone explain or refering me to some document that explain this?
Thank you very much
Regards
- Re: Conceptual understanding of IOC software architecture Eric Norum
- Conceptual understanding of IOC software architecture Diego Sanz
Re: sequencer installation Ralph Lange
Re: sequencer installation Kasemir, Kay
<2014>
<2014>
ANJ, 17 Dec 2015 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
