This type of instrument will be rather hard to test using a simple terminal program. Lots of non-ASCII characters to type. But it shouldn’t be too hard to write support using StreamDevice. In particular, StreamDevice makes it easy to generate the simple ‘XOR’ check byte that the Siemens USS protocol requires.
Or, perhaps someone has already written an ASYN interpose interface to handle the USS protocol? I need helps... ^.^ I have a TD20 Classic turbo molecular pump controller... it was produced by Leybold.. First, I want to signal test using terminal program like hyperterminal.. It uses USS protocol.. I got a signal hexacode... I attached the document. It can or can not ? Second, I want to control by SIEMENS PLC or AB PLC ...then integrate into EPICS.. Anyone who got a source.. control TD20 classic TMP controller... help me.. Sincerely, Suk Choi
- TD20 classic : Turbo molecular pump controller "최숙"
Re: WG: Re: motorRecord on linux-arm Ron Sluiter
protol file erro: Field width out of range 张德敏
<2014>
<2014>
ANJ, 17 Dec 2015 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
