I have a TD20 Classic turbo molecular pump controller... it was produced by Leybold..
First, I want to signal test using terminal program like hyperterminal.. It uses USS protocol.. I got a signal hexacode... I attached the document. It can or can not ?
Second, I want to control by SIEMENS PLC or AB PLC ...then integrate into EPICS.. Anyone who got a source.. control TD20 classic TMP controller... help me..
Sincerely, Suk Choi
Examples of a
USS protocol at RS 232 interface
To understand
the structure of a USS protocol are some examples written inside this document.
Please see in addition the interface manual.
Once the master (PC) has sent
a telegram to the slave (CT), the answer will follow after a delay of 10
ms in case the telegram was received
correctly
An empty
telegram without any task to the slave:
Master: 02 16 00 00 00 00 00 00 00 00
00 00 00 00 00 00 00 00 00 00 00 00 00 14
Slave : 02 16 00 00 00 00 00 00 00 00
00 02 01 00 00 00 1E 00 00 00 16 00 E9 F6
The slave
will only transmit his processwords.
Calculation
of the BCC for upper example:
BCC
:0000 0000 xor
byte1 :0000
0010 =
BCC
:0000 0010 xor
byte2 :0001
0110 =
BCC
:0001 0100 xor
byte3 :0000
0000 =
BCC
:0001 0100 xor
BCC
:0001 0100 xor
byte23:0000
0000 =
BCC
:0001 0100
Examples of
what your interface should be able to do:
Reading of
parameters:
For example
the value of parameter 23 should be read out. This parameter shows the pump
type:
Master: 02 16 00 10 17 00 00 00 00 00
00 00 00 00 00 00 00 00 00 00 00 00 00 13
Slave : 02 16 00 10 17 00 00 00 00 00
04 02 01 00 00 00 1E 00 00 00 15 00 E9 F6
Byte 3-4
contens the type of request (please see the interface manual) and the parameter
number. The slave answers with the value "00 00 00 04". This is
according to the manual a TW 300 (please see converter manual).
Writing of
parameters:
According to
the pump type the program will select the right maximum speed out of the list. Imagine
the pump should run with 1000Hz. Parameter 24 appoints the maximum speed:
Master: 02 16 00 20 18 00 00 00 00 03
E8 00 00 00 00 00 00 00 00 00 00 00 00 C7
Slave : 02 16 00 10 18 00 00 00 00 03
E8 02 01 00 00 00 1E 00 00 00 15 00 E9 16
The slave
answers with the new value.
Start the
pump:
You will
start the pump by using the control-word (please see the interface manual).
E8 04 01 00 00 00 00 00 00 00 00 00 00 C2
Inside this
example also the maximum speed of the pump will be set.
Stop the pump:
You will stop
00 04 00 00 00 00 00 00 00 00 00 00 00 10
00 8E 24 03 13 00 1F 00 18 00 16 00 E3 5C
ANJ, 17 Dec 2015 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
