1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: RE: how to know which PVs write to a PV
To: "Arnold, Ned D." <[email protected]>, LEI Ge <[email protected]>, "[email protected]" <[email protected]>
Date: Tue, 27 May 2014 14:30:53 +0000
Hi Ned,
Yes, your approach is really a quicker way. How about the idea of integrating your code (or similar implementation) with the field TPRO in the dbProcess()?
I did a quick test and put your code in base-3.14.12.2/src/db/dbAccess.c. With a few other changes on Makefile, I re-compiled my EPICS base and example ioc without problem. And the code below works: if recordName.TPRO is set to 1, this will show more information -- who is doing CA put from which machine, the message like this:
CAS-client: Process yhuHost:aiExample
CA put to yhuHost:aiExample by user yhu from host box32
/*trying to adapt Ned's code inside dbProcess()*/
long epicsShareAPI dbProcess(dbCommon *precord)
	if(*ptrace) printf("%s: Process %s\n",
			epicsThreadGetNameSelf(), precord->name);
	if(*ptrace){
	    tid = epicsThreadGetIdSelf();
	    LOCK_CLIENTQ;
            for(pclient=(struct client*)ellFirst(&clientQ);
                pclient && pclient->tid!=tid;
                pclient=(struct client*)ellNext(&pclient->node)
            if(pclient)
              sprintf(result,"user %s from host %s",pclient->pUserName,pclient->pHostName);
            else
              sprintf(result,"Internal: TID = %p",tid);
            UNLOCK_CLIENTQ;
            printf("CA put to %s by %s\n",precord->name,result);
	/* process record */
	status = (*prset->process)(precord);
Yong
From: [email protected] [[email protected]] on behalf of Arnold, Ned D. [[email protected]]
Sent: Thursday, May 22, 2014 9:47 AM
To: LEI Ge; [email protected]
Yet another <quicker> way to determine which host wrote to a PV:
1) Load a subroutine record into the IOC using the code below
2) Include this subroutine record in the record processing chain of the record you want to monitor. You can use a FLNK or SDIS for this (make sure that it is *not* a CA  or CP link).
When the record processes, you see something like this ...
ioclic1> caHostId: ioclic1:caHostId1: nda from chiron
We have a few of these subroutine records in all IOCs, so if we need to track down an errant "write" we can just change a few links ... without rebooting.
  Ned
RECORD
record(sub,"$(IOC):caHostId1") {
        field(INAM,"caHostIdI")
        field(SNAM,"caHostId")
SUBROUTINE
/* subroutine for determining host/uid of CA client
 * DESC : String identifying Username & Host
#include        <stdio.h>
#include        <string.h>
#include        <dbEvent.h>
#include        <osiSock.h>
#include        <ellLib.h>
#include        <server.h>
#include <dbDefs.h>
#include <registryFunction.h>
#include <subRecord.h>
#include <epicsExport.h>
static long  caHostIdI(subRecord* pr)
    return(0);
static long  caHostId(subRecord* pr)
    char  result[100];
    epicsThreadId tid = epicsThreadGetIdSelf();
    struct client* pclient;
    LOCK_CLIENTQ;
    if(pclient)
      sprintf(result,"%s from %s",pclient->pUserName,pclient->pHostName);
    else
    UNLOCK_CLIENTQ;
    strncpy(pr->desc, result, sizeof(pr->desc));
    pr->desc[sizeof(pr->desc)-1] = '\0';
    db_post_events(pr, pr->desc, 1);
    pr->val = pr->a;  /* set val to value of Input A */
    printf("caHostId: %s: %s\n",pr->name,result);
    return(0);
static registryFunctionRef caHostIdRef[] = {
    {"caHostIdI",(REGISTRYFUNCTION)caHostIdI},
    {"caHostId",(REGISTRYFUNCTION)caHostId}
static void caHostIdRegister(void)
    registryFunctionRefAdd(caHostIdRef,NELEMENTS(caHostIdRef));
epicsExportRegistrar(caHostIdRegister);
From: [email protected] [[email protected]] on behalf of LEI Ge [[email protected]]
Sent: Wednesday, May 21, 2014 03:54 AM
To: [email protected]
Subject: how to know which PVs write to a PV
Hi, all,
This week we met a problem, a PV's value should be 1 (to enable our e-gun trigger), but sometimes it becomes 0 unexpectedly. I checked the software logic I can remember to this pv, and have not found the reason. Maybe there is some logic I forget or I don't know, to write to this pv. So is there a way to check in our control system, which PVs write to this pv? Or, this PV is written from which IP?
Thanks a lot ,
Ge
Re: how to know which PVs write to a PV Andrew Johnson
how to know which PVs write to a PV LEI Ge
RE: how to know which PVs write to a PV Arnold, Ned D.
Prev: how can I caget a PV's Value in the callback function of the caClient? ahwwq
Next: Job opportunities at ESS Timo Korhonen
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: RE: how to know which PVs write to a PV Arnold, Ned D.
Next: Re: how to know which PVs write to a PV Andrew Johnson
ANJ, 17 Dec 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
