Hello, I'm having issues building areaDetector with Windows 7 x64. First issue is with the Nexus file plugin, the second is with the StdArrays plugin (error messages at end of post).GnuMake32 3.81 (in C:\GnuMake32) .NET 4.0Win7 SDK for 64-bit compilers and VS2010 base 3.14.12.4 (SHARED LIBRARIES = YES, STATIC BUILD =NO) areaDetector-r2-0 Base and Synapps have built successfully. I've set up areaDetector per the guide here: https://github.com/areaDetector/areaDetector/blob/master/INSTALL_GUIDE.md make will error out when building the Nexus plugin because it can't find hdf5.h. Adding $(info "$(HDF5_INCLUDE)") into the nexus makefile shows an empty string. It seems that the HDF5_INCLUDE variable is not getting passed from $(AREA_DETECTOR)/configure/CONFIG_SITE.local. Copying the required files over from ADBinaries will allow the Nexus plugin to build. ADBinaries, NetCDF, jpg, and tiff plugins all build successfully. pluginSrc errors out (I think) when looking for the Asyn libraries when it opens NDPluginDriver.cpp. Not entire certain of that, but if I comment out NDPluginDriver.cpp from the make file, it will error out at NDPluginStdArrays looking for getAsynStdInterfaces. (As a side note, I noticed while troubleshooting that HDF5_INCLUDE is not getting passed here either.) Probably just some pathing issues, but I have been stumped for a while. -ZB nexus error: make -C ./nexusSrc install make[3]: Entering directory `C:/epics/areaDetector-R2-0/ADCore/ADApp/nexusSrc' make -C O.windows-x64 -f ../Makefile TOP=../../.. T_A=windows-x64 install "../../.." make[4]: Entering directory `C:/epics/areaDetector-R2-0/ADCore/ADApp/nexusSrc/O.windows-x64' cl -c /favor:blend /nologo /D__STDC__=0 /D_CRT_SECURE_NO_DEPRECATE /D_CRT_NONSTDC_NO_DEPRECATE /Ox /GL /W3 /w44355 -DHDF5 -D_FILE_OFFSET_BITS=64 -DH5_BUILT_AS_DYNAMIC_LIB /MD -I. -I..\\O.Common -I. -I.. -I..\\..\ \..\\include\\os\\WIN32 -I..\\..\\..\\include -IC:\\epics\\base-3.14.12.4\\include\\os\\WIN32 -IC:\\epics\\base-3.14 .12.4\\include -IC:\\epics\\synApps_5_7\\support\\asyn-4-21\\include ..\\napi.c napi.c c:\epics\areadetector-r2-0\adcore\adapp\nexussrc\napi5.h(6) : fatal error C1083: Cannot open include file: 'hdf5.h': No such file or directory make[4]: *** [napi.obj] Error 2 make[4]: Leaving directory `C:/epics/areaDetector-R2-0/ADCore/ADApp/nexusSrc/O.windows-x64' make[3]: *** [install.windows-x64] Error 2 make[3]: Leaving directory `C:/epics/areaDetector-R2-0/ADCore/ADApp/nexusSrc' make[2]: *** [nexusSrc.install] Error 2 make[2]: Leaving directory `C:/epics/areaDetector-R2-0/ADCore/ADApp' make[1]: *** [ADApp.install] Error 2 make[1]: Leaving directory `C:/epics/areaDetector-R2-0/ADCore' make: *** [ADCore.install] Error 2 make: Leaving directory `C:/epics/areaDetector-R2-0' pluginSrc error: make: Entering directory `c:/epics/areaDetector-R2-0/ADCore/ADApp/pluginSrc' make -C O.windows-x64 -f ../Makefile TOP=../../.. T_A=windows-x64 install make[1]: Entering directory `c:/epics/areaDetector-R2-0/ADCore/ADApp/pluginSrc/O.windows-x64' cl /nologo /EHsc /GR -c /favor:blend /nologo /D__STDC__=0 /D_CRT_SECURE_NO_DEPRECATE /D_CRT_NONSTDC_NO_DEP RECATE /Ox /GL /W3 /w44355 -DLIBTIFF_STATIC -DH5_BUILT_AS_DYNAMIC_LIB /MD /TP -I. -I..\\O.Common -I. -I.. - I..\\..\\..\\include\\os\\WIN32 -I..\\..\\..\\include -IC:\\epics\\base-3.14.12.4\\include\\os\\WIN32 -IC:\\epics\\b ase-3.14.12.4\\include -IC:\\epics\\synApps_5_7\\support\\asyn-4-21\\include ..\\NDPluginDriver.cpp NDPluginDriver.cpp ..\NDPluginDriver.cpp(60) : error C3861: 'setTimeStamp': identifier not found make[1]: *** [NDPluginDriver.obj] Error 2 make[1]: Leaving directory `c:/epics/areaDetector-R2-0/ADCore/ADApp/pluginSrc/O.windows-x64' make: *** [install.windows-x64] Error 2 make: Leaving directory `c:/epics/areaDetector-R2-0/ADCore/ADApp/pluginSrc'
ANJ, 17 Dec 2015 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
