1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Newport XPS-Q8 and Motor Record - armv5teb architecture
To: "Johnson, Andrew N." <[email protected]>, "Rivers, Mark L." <[email protected]>
Cc: "[email protected]" <[email protected]>, Tonia Batten <[email protected]>
Date: Thu, 8 May 2014 08:13:42 +0200
On 5/7/14 11:32 PM, Johnson, Andrew N. wrote:
Hi Mark,
You could try adding a call to the gcc built-in routine __sync_synchronize(); after the last write to the asynUser structure. This implements a full memory barrier, which is equivalent to the two memory barriers inside the mutex operations. If this fixes it for ARM there is probably a better solution, but this will at least identify if this is the cause of the problem.
This would be needed on a multi-core system.
What system is in use ?
single core or multi core?
I just got the motor simulator working on the Raspberry PI, (after some days of debugging)
The trick was to use this block in motorApp/MotorSrc/motor.h:
/* Define, from top to bottom, how bit fields are packed. */
/* This works for gnu, SunPro, MS Visual C. */
#include <epicsEndian.h>
#if (EPICS_BYTE_ORDER == EPICS_ENDIAN_LITTLE)
    #define LSB_First (TRUE)
    #warning LSB_First
#endif
#if (EPICS_BYTE_ORDER == EPICS_ENDIAN_BIG)
    #define MSB_First (TRUE)
    #warning MSB_First
#endif
What do you get when you compile with this change ? MSB_First or LSB_First ?
RE: Newport XPS-Q8 and Motor Record - armv5teb architecture Tonia Batten
RE: Newport XPS-Q8 and Motor Record - armv5teb architecture Mark Rivers
Re: Newport XPS-Q8 and Motor Record - armv5teb architecture J. Lewis Muir
Re: Newport XPS-Q8 and Motor Record - armv5teb architecture Stephen Beckwith
Re: Newport XPS-Q8 and Motor Record - armv5teb architecture Jens Eden
Re: Newport XPS-Q8 and Motor Record - armv5teb architecture Johnson, Andrew N.
Prev: RE: ADLightField Prebuilt - LightField.dll Not Found Mark Rivers
Next: support for oriel cornerstone monochromator David M. Kline
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: Newport XPS-Q8 and Motor Record - armv5teb architecture Johnson, Andrew N.
Next: RE: Newport XPS-Q8 and Motor Record - armv5teb architecture Tonia Batten
ANJ, 17 Dec 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
