field(EGU, "degrees C")
field(LINR, "LINEAR")
field(SCAN, "1 second")
field(HIHI, "250")
field(HHSV, "MAJOR")
Could anyone help me to understand why I get always 0 using caget but I get right value from snmpget?
Thank you very much.
Kind regards,
Nicoletta
The snmpwalk gives
-bash-4.1$ snmpwalk -v1 -c public 192.168.58.96
SNMPv2-MIB::sysDescr.0 = STRING: TME
SNMPv2-MIB::sysObjectID.0 = OID: ccitt.9.43.6.1.4.1
DISMAN-EVENT-MIB::sysUpTimeInstance = Timeticks: (10197595) 1 day, 4:19:35.95
SNMPv2-MIB::sysContact.0 = STRING:
SNMPv2-MIB::sysName.0 = STRING:
SNMPv2-MIB::sysLocation.0 = STRING:
SNMPv2-MIB::sysServices.0 = INTEGER: 12
IF-MIB::ifNumber.0 = INTEGER: 1
IF-MIB::ifIndex.1 = INTEGER: 1
IF-MIB::ifDescr.1 = STRING: Network
IF-MIB::ifType.1 = INTEGER: ethernetCsmacd(6)
IF-MIB::ifMtu.1 = INTEGER: 1500
IF-MIB::ifSpeed.1 = Gauge32: 10000000
IF-MIB::ifPhysAddress.1 = STRING: 0:20:4a:c9:63:bd
IF-MIB::ifAdminStatus.1 = INTEGER: up(1)
IF-MIB::ifOperStatus.1 = INTEGER: up(1)
IF-MIB::ifLastChange.1 = Timeticks: (0) 0:00:00.00
IF-MIB::ifInOctets.1 = Counter32: 13254469
IF-MIB::ifInUcastPkts.1 = Counter32: 185466
IF-MIB::ifInNUcastPkts.1 = Counter32: 0
IF-MIB::ifInDiscards.1 = Counter32: 0
IF-MIB::ifInErrors.1 = Counter32: 0
IF-MIB::ifInUnknownProtos.1 = Counter32: 0
IF-MIB::ifOutOctets.1 = Counter32: 356137879
IF-MIB::ifOutUcastPkts.1 = Counter32: 11019
IF-MIB::ifOutNUcastPkts.1 = Counter32: 665
IF-MIB::ifOutDiscards.1 = Counter32: 0
IF-MIB::ifOutErrors.1 = Counter32: 0
IF-MIB::ifOutQLen.1 = Gauge32: 2
IP-MIB::ipForwarding.0 = INTEGER: notForwarding(2)
IP-MIB::ipDefaultTTL.0 = INTEGER: 31
IP-MIB::ipInReceives.0 = Counter32: 44978
IP-MIB::ipInHdrErrors.0 = Wrong Type (should be Counter32): INTEGER: 0
IP-MIB::ipInAddrErrors.0 = Wrong Type (should be Counter32): INTEGER: 0
IP-MIB::ipForwDatagrams.0 = Counter32: 0
IP-MIB::ipInUnknownProtos.0 = Counter32: 0
IP-MIB::ipInDiscards.0 = Wrong Type (should be Counter32): INTEGER: 0
IP-MIB::ipInDelivers.0 = Counter32: 44984
IP-MIB::ipOutRequests.0 = Counter32: 0
IP-MIB::ipOutDiscards.0 = Wrong Type (should be Counter32): INTEGER: 0
IP-MIB::ipOutNoRoutes.0 = Wrong Type (should be Counter32): INTEGER: 0
IP-MIB::ipReasmTimeout.0 = INTEGER: 0 seconds
IP-MIB::ipReasmReqds.0 = Wrong Type (should be Counter32): INTEGER: 0
IP-MIB::ipReasmOKs.0 = Wrong Type (should be Counter32): INTEGER: 0
IP-MIB::ipReasmFails.0 = Wrong Type (should be Counter32): INTEGER: 0
IP-MIB::ipFragOKs.0 = Wrong Type (should be Counter32): INTEGER: 0
IP-MIB::ipFragFails.0 = Wrong Type (should be Counter32): INTEGER: 0
IP-MIB::ipFragCreates.0 = Wrong Type (should be Counter32): INTEGER: 0
IP-MIB::ipAdEntAddr.192.168.58.96 = IpAddress: 192.168.58.96
IP-MIB::ipAdEntIfIndex.192.168.58.96 = INTEGER: 1
IP-MIB::ipAdEntNetMask.192.168.58.96 = IpAddress: 255.255.255.0
IP-MIB::ipAdEntBcastAddr.192.168.58.96 = INTEGER: 1
IP-MIB::ipAdEntReasmMaxSize.192.168.58.96 = INTEGER: 0
IP-MIB::icmpInMsgs.0 = Counter32: 0
IP-MIB::icmpInErrors.0 = Wrong Type (should be Counter32): INTEGER: 0
IP-MIB::icmpInDestUnreachs.0 = Counter32: 0
IP-MIB::icmpInTimeExcds.0 = Counter32: 0
IP-MIB::icmpInParmProbs.0 = Counter32: 0
IP-MIB::icmpInSrcQuenchs.0 = Counter32: 0
IP-MIB::icmpInRedirects.0 = Counter32: 0
IP-MIB::icmpInEchos.0 = Counter32: 0
IP-MIB::icmpInEchoReps.0 = Counter32: 0
IP-MIB::icmpInTimestamps.0 = Counter32: 0
IP-MIB::icmpInTimestampReps.0 = Wrong Type (should be Counter32): INTEGER: 0
IP-MIB::icmpInAddrMasks.0 = Wrong Type (should be Counter32): INTEGER: 0
IP-MIB::icmpInAddrMaskReps.0 = Wrong Type (should be Counter32): INTEGER: 0
IP-MIB::icmpOutMsgs.0 = Counter32: 0
IP-MIB::icmpOutErrors.0 = Wrong Type (should be Counter32): INTEGER: 0
IP-MIB::icmpOutDestUnreachs.0 = Counter32: 120
IP-MIB::icmpOutTimeExcds.0 = Wrong Type (should be Counter32): INTEGER: 0
IP-MIB::icmpOutParmProbs.0 = Wrong Type (should be Counter32): INTEGER: 0
IP-MIB::icmpOutSrcQuenchs.0 = Wrong Type (should be Counter32): INTEGER: 0
IP-MIB::icmpOutRedirects.0 = Wrong Type (should be Counter32): INTEGER: 0
IP-MIB::icmpOutEchos.0 = Wrong Type (should be Counter32): INTEGER: 0
IP-MIB::icmpOutEchoReps.0 = Counter32: 0
IP-MIB::icmpOutTimestamps.0 = Wrong Type (should be Counter32): INTEGER: 0
IP-MIB::icmpOutTimestampReps.0 = Wrong Type (should be Counter32): INTEGER: 0
IP-MIB::icmpOutAddrMasks.0 = Wrong Type (should be Counter32): INTEGER: 0
IP-MIB::icmpOutAddrMaskReps.0 = Wrong Type (should be Counter32): INTEGER: 0
UDP-MIB::udpInDatagrams.0 = Counter32: 24553
UDP-MIB::udpNoPorts.0 = Counter32: 3526
UDP-MIB::udpInErrors.0 = Counter32: 13349
UDP-MIB::udpOutDatagrams.0 = Counter32: 494
