1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Device/Driver Support for Stepper Motor Control
To: Ron Sluiter <[email protected]>
Cc: <[email protected]>
Date: Tue, 6 May 2014 15:43:12 -0400
Hi Ron,
Thank you for the swift reply.  Just want to verify that Jens' asyn motor support for OMS MAXnet controller does support soft IOC, correct?  Besides, should I use asyn drvAsynIPPort as the driver support with Jen's asyn motor support?
William Lu
----- Original Message -----
To: "Weiwei Lu" <[email protected]>, [email protected]
Cc: "Jens Eden" <[email protected]>
Sent: Tuesday, May 6, 2014 3:26:00 PM
Hello William,
Jens Eden (PTB) added asyn motor support for both the OMS MAXv and the OMS MAXnet controllers. That support is available beginning with the latest release (R6-8) of the motor module.
Ron
On 5/6/2014 2:18 PM, Weiwei Lu wrote:
We plan to use a soft IOC and an OMS MAXnet motion controller to control a stepper motor.  The soft IOC will communicate with the MAXnet motion controller's Ethernet interface.  What are the existing EPICS device/driver supports that we can use for this soft IOC application?  Can APS's Stepper/DC Motor Controller software or Mark Rivers' devMotorAsyn and drvMotorAsyn be used for this?  What are the pros and cons comparing these two technologies?  Are there other alternatives?
Advice is greatly appreciated.  Thank you in advance.
William Lu
RE: Device/Driver Support for Stepper Motor Control Mark Rivers
Re: Device/Driver Support for Stepper Motor Control Ron Sluiter
Prev: Re: Device/Driver Support for Stepper Motor Control Ron Sluiter
Next: RE: Device/Driver Support for Stepper Motor Control Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024
ANJ, 17 Dec 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
