Dear all,
I have got installed a TME - Ethernet Thermometer, (http://www.papouch.com/en/shop/product/tme-ip-ethernet-thermometer/) which supports SNMP protocol, and I would like to read the temperature using EPICS with devSnmp.
My simple database is record(ai, "TME:TempTimes10") { field(DESC, "TME Temperarature sensor") field(DTYP, "Snmp") field(INP, "@192.168.58.96 public SNMPv2-SMI::enterprises.18248.1.1.1.0 Float: 100") field(EGU, "degrees C") field(LINR, "LINEAR") field(SCAN, "1 second") field(HIHI, "250") field(HHSV, "MAJOR")
The ioc runs ok without errors, but with caget I only get 0 as temperature’s value, and with camonitor I get the value is INVALID
-bash-4.1$ camonitor TME:TempTimes10 TME:TempTimes10 2014-05-06 16:43:11.479828 0 READ INVALID
I posted a similar question a while ago for a different monitor, and at that time I solved the problem using an OID name as given back from snmpget, but this solution does not work this time.
-bash-4.1$ snmpget -v1 -c public 192.168.58.96 1.3.6.1.4.1.18248.1.1.1.0 SNMPv2-SMI::enterprises.18248.1.1.1.0 = INTEGER: 182 -bash-4.1$ The OID name seems to be ok, so I cannot understand why I keep obtaining 0 as a value from caget, and I can get right value from snmp.
The same ioc works ok with a different module and with the following database record(ai, "TCW122B:Temp1Times10")
{ field(DESC, "Temperarature sensor 1") field(DTYP, "Snmp") field(INP, "@145.239.84.45 public SNMPv2-SMI::enterprises.38783.3.9.0 INTEGER: 100") field(EGU, "degrees C") field(LINR, "LINEAR") field(SCAN, "1 second") field(HIHI, "250") field(HHSV, "MAJOR") }
Could anyone help me to understand why I get always 0 using caget but I get right value from snmpget? Thank you very much. Kind regards, Nicoletta
The snmpwalk gives
-bash-4.1$ snmpwalk -v1 -c public 192.168.58.96 SNMPv2-MIB::sysDescr.0 = STRING: TME SNMPv2-MIB::sysObjectID.0 = OID: ccitt.9.43.6.1.4.1 DISMAN-EVENT-MIB::sysUpTimeInstance = Timeticks: (10197595) 1 day, 4:19:35.95 SNMPv2-MIB::sysContact.0 = STRING: SNMPv2-MIB::sysName.0 = STRING: SNMPv2-MIB::sysLocation.0 = STRING: SNMPv2-MIB::sysServices.0 = INTEGER: 12 IF-MIB::ifNumber.0 = INTEGER: 1 IF-MIB::ifIndex.1 = INTEGER: 1 IF-MIB::ifDescr.1 = STRING: Network IF-MIB::ifType.1 = INTEGER: ethernetCsmacd(6) IF-MIB::ifMtu.1 = INTEGER: 1500 IF-MIB::ifSpeed.1 = Gauge32: 10000000 IF-MIB::ifPhysAddress.1 = STRING: 0:20:4a:c9:63:bd IF-MIB::ifAdminStatus.1 = INTEGER: up(1) IF-MIB::ifOperStatus.1 = INTEGER: up(1) IF-MIB::ifLastChange.1 = Timeticks: (0) 0:00:00.00 IF-MIB::ifInOctets.1 = Counter32: 13254469 IF-MIB::ifInUcastPkts.1 = Counter32: 185466 IF-MIB::ifInNUcastPkts.1 = Counter32: 0 IF-MIB::ifInDiscards.1 = Counter32: 0 IF-MIB::ifInErrors.1 = Counter32: 0 IF-MIB::ifInUnknownProtos.1 = Counter32: 0 IF-MIB::ifOutOctets.1 = Counter32: 356137879 IF-MIB::ifOutUcastPkts.1 = Counter32: 11019 IF-MIB::ifOutNUcastPkts.1 = Counter32: 665 IF-MIB::ifOutDiscards.1 = Counter32: 0 IF-MIB::ifOutErrors.1 = Counter32: 0 IF-MIB::ifOutQLen.1 = Gauge32: 2 IP-MIB::ipForwarding.0 = INTEGER: notForwarding(2) IP-MIB::ipDefaultTTL.0 = INTEGER: 31 IP-MIB::ipInReceives.0 = Counter32: 44978 IP-MIB::ipInHdrErrors.0 = Wrong Type (should be Counter32): INTEGER: 0 IP-MIB::ipInAddrErrors.0 = Wrong Type (should be Counter32): INTEGER: 0 IP-MIB::ipForwDatagrams.0 = Counter32: 0 IP-MIB::ipInUnknownProtos.0 = Counter32: 0 IP-MIB::ipInDiscards.0 = Wrong Type (should be Counter32): INTEGER: 0 IP-MIB::ipInDelivers.0 = Counter32: 44984 IP-MIB::ipOutRequests.0 = Counter32: 0 IP-MIB::ipOutDiscards.0 = Wrong Type (should be Counter32): INTEGER: 0 IP-MIB::ipOutNoRoutes.0 = Wrong Type (should be Counter32): INTEGER: 0 IP-MIB::ipReasmTimeout.0 = INTEGER: 0 seconds IP-MIB::ipReasmReqds.0 = Wrong Type (should be Counter32): INTEGER: 0 IP-MIB::ipReasmOKs.0 = Wrong Type (should be Counter32): INTEGER: 0 IP-MIB::ipReasmFails.0 = Wrong Type (should be Counter32): INTEGER: 0 IP-MIB::ipFragOKs.0 = Wrong Type (should be Counter32): INTEGER: 0 IP-MIB::ipFragFails.0 = Wrong Type (should be Counter32): INTEGER: 0 IP-MIB::ipFragCreates.0 = Wrong Type (should be Counter32): INTEGER: 0 IP-MIB::ipAdEntAddr.192.168.58.96 = IpAddress: 192.168.58.96 IP-MIB::ipAdEntIfIndex.192.168.58.96 = INTEGER: 1 IP-MIB::ipAdEntNetMask.192.168.58.96 = IpAddress: 255.255.255.0 IP-MIB::ipAdEntBcastAddr.192.168.58.96 = INTEGER: 1 IP-MIB::ipAdEntReasmMaxSize.192.168.58.96 = INTEGER: 0 IP-MIB::icmpInMsgs.0 = Counter32: 0 IP-MIB::icmpInErrors.0 = Wrong Type (should be Counter32): INTEGER: 0 IP-MIB::icmpInDestUnreachs.0 = Counter32: 0 IP-MIB::icmpInTimeExcds.0 = Counter32: 0 IP-MIB::icmpInParmProbs.0 = Counter32: 0 IP-MIB::icmpInSrcQuenchs.0 = Counter32: 0 IP-MIB::icmpInRedirects.0 = Counter32: 0 IP-MIB::icmpInEchos.0 = Counter32: 0 IP-MIB::icmpInEchoReps.0 = Counter32: 0 IP-MIB::icmpInTimestamps.0 = Counter32: 0 IP-MIB::icmpInTimestampReps.0 = Wrong Type (should be Counter32): INTEGER: 0 IP-MIB::icmpInAddrMasks.0 = Wrong Type (should be Counter32): INTEGER: 0 IP-MIB::icmpInAddrMaskReps.0 = Wrong Type (should be Counter32): INTEGER: 0 IP-MIB::icmpOutMsgs.0 = Counter32: 0 IP-MIB::icmpOutErrors.0 = Wrong Type (should be Counter32): INTEGER: 0 IP-MIB::icmpOutDestUnreachs.0 = Counter32: 120 IP-MIB::icmpOutTimeExcds.0 = Wrong Type (should be Counter32): INTEGER: 0 IP-MIB::icmpOutParmProbs.0 = Wrong Type (should be Counter32): INTEGER: 0 IP-MIB::icmpOutSrcQuenchs.0 = Wrong Type (should be Counter32): INTEGER: 0 IP-MIB::icmpOutRedirects.0 = Wrong Type (should be Counter32): INTEGER: 0 IP-MIB::icmpOutEchos.0 = Wrong Type (should be Counter32): INTEGER: 0 IP-MIB::icmpOutEchoReps.0 = Counter32: 0 IP-MIB::icmpOutTimestamps.0 = Wrong Type (should be Counter32): INTEGER: 0 IP-MIB::icmpOutTimestampReps.0 = Wrong Type (should be Counter32): INTEGER: 0 IP-MIB::icmpOutAddrMasks.0 = Wrong Type (should be Counter32): INTEGER: 0 IP-MIB::icmpOutAddrMaskReps.0 = Wrong Type (should be Counter32): INTEGER: 0 UDP-MIB::udpInDatagrams.0 = Counter32: 24553 UDP-MIB::udpNoPorts.0 = Counter32: 3526 UDP-MIB::udpInErrors.0 = Counter32: 13349 UDP-MIB::udpOutDatagrams.0 = Counter32: 494
....@(';')@....... ..0==/--\==0.... ....../___\........ ......_| |_.........
ANJ, 17 Dec 2015 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
