1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Trouble with OID name using devsnmp.
To: Nicoletta Petrella <[email protected]>
Cc: <[email protected]>
Date: Tue, 6 May 2014 09:27:09 -0700
Disclaimer — I know very little about SNMP.
But I do see a possible issue.
In the version that works you’re asking for an INTEGER — which is what the snmpget and snmpwalk show as well.
field(INP,  "@145.239.84.45 public SNMPv2-SMI::enterprises.38783.3.9.0  INTEGER: 100”)
In the version that fails you’re asking for a Float — which doesn’t match.
field(INP,  "@192.168.58.96 public  SNMPv2-SMI::enterprises.18248.1.1.1.0  Float: 100”)
Try changing the ‘Float’ in the INP field to ‘INTEGER’ and see if that helps.
On May 6, 2014, at 9:00 AM, Nicoletta Petrella <[email protected]> wrote:
Dear all,
I have got installed a TME - Ethernet Thermometer, (http://www.papouch.com/en/shop/product/tme-ip-ethernet-thermometer/) which supports SNMP protocol, and I would like to read the temperature using EPICS with devSnmp.
My simple database is
record(ai, "TME:TempTimes10")
    field(DESC, "TME Temperarature sensor")
    field(DTYP, "Snmp")
    field(INP,  "@192.168.58.96 public  SNMPv2-SMI::enterprises.18248.1.1.1.0  Float: 100")
    field(EGU,  "degrees C")
    field(LINR, "LINEAR")
    field(SCAN, "1 second")
    field(HIHI, "250")
    field(HHSV, "MAJOR")
The ioc runs ok without errors,  but with caget I only get 0 as temperature’s value, and with camonitor I get the value is INVALID
-bash-4.1$ camonitor TME:TempTimes10
TME:TempTimes10                2014-05-06 16:43:11.479828 0 READ INVALID
I posted a similar question a while ago for a different monitor, and at that time I solved  the problem using an OID name as given back from snmpget, but this solution does not work this time.
-bash-4.1$ snmpget -v1 -c public 192.168.58.96 1.3.6.1.4.1.18248.1.1.1.0
SNMPv2-SMI::enterprises.18248.1.1.1.0 = INTEGER: 182
-bash-4.1$
The OID name seems to be ok, so I cannot understand why I keep obtaining 0 as a value from caget, and I can get right value from snmp.
The same ioc works ok with a different module and with the following database
record(ai, "TCW122B:Temp1Times10")
    field(DESC, "Temperarature sensor 1")
    field(DTYP, "Snmp")
    field(INP,  "@145.239.84.45 public SNMPv2-SMI::enterprises.38783.3.9.0  INTEGER: 100")
    field(HIHI, "250")
Could anyone help me to understand why I get always 0 using caget but I get right value from snmpget?
Thank you very much.
Kind regards,
Nicoletta
The snmpwalk gives
-bash-4.1$ snmpwalk -v1 -c public 192.168.58.96
SNMPv2-MIB::sysDescr.0 = STRING: TME
SNMPv2-MIB::sysObjectID.0 = OID: ccitt.9.43.6.1.4.1
DISMAN-EVENT-MIB::sysUpTimeInstance = Timeticks: (10197595) 1 day, 4:19:35.95
SNMPv2-MIB::sysContact.0 = STRING:
SNMPv2-MIB::sysName.0 = STRING:
SNMPv2-MIB::sysLocation.0 = STRING:
SNMPv2-MIB::sysServices.0 = INTEGER: 12
IF-MIB::ifNumber.0 = INTEGER: 1
IF-MIB::ifIndex.1 = INTEGER: 1
IF-MIB::ifDescr.1 = STRING: Network
IF-MIB::ifType.1 = INTEGER: ethernetCsmacd(6)
IF-MIB::ifMtu.1 = INTEGER: 1500
IF-MIB::ifSpeed.1 = Gauge32: 10000000
IF-MIB::ifPhysAddress.1 = STRING: 0:20:4a:c9:63:bd
IF-MIB::ifAdminStatus.1 = INTEGER: up(1)
IF-MIB::ifOperStatus.1 = INTEGER: up(1)
IF-MIB::ifLastChange.1 = Timeticks: (0) 0:00:00.00
IF-MIB::ifInOctets.1 = Counter32: 13254469
IF-MIB::ifInUcastPkts.1 = Counter32: 185466
IF-MIB::ifInNUcastPkts.1 = Counter32: 0
IF-MIB::ifInDiscards.1 = Counter32: 0
IF-MIB::ifInErrors.1 = Counter32: 0
IF-MIB::ifInUnknownProtos.1 = Counter32: 0
IF-MIB::ifOutOctets.1 = Counter32: 356137879
IF-MIB::ifOutUcastPkts.1 = Counter32: 11019
IF-MIB::ifOutNUcastPkts.1 = Counter32: 665
IF-MIB::ifOutDiscards.1 = Counter32: 0
IF-MIB::ifOutErrors.1 = Counter32: 0
IF-MIB::ifOutQLen.1 = Gauge32: 2
IP-MIB::ipForwarding.0 = INTEGER: notForwarding(2)
IP-MIB::ipDefaultTTL.0 = INTEGER: 31
IP-MIB::ipInReceives.0 = Counter32: 44978
IP-MIB::ipInHdrErrors.0 = Wrong Type (should be Counter32): INTEGER: 0
IP-MIB::ipInAddrErrors.0 = Wrong Type (should be Counter32): INTEGER: 0
IP-MIB::ipForwDatagrams.0 = Counter32: 0
IP-MIB::ipInUnknownProtos.0 = Counter32: 0
IP-MIB::ipInDiscards.0 = Wrong Type (should be Counter32): INTEGER: 0
IP-MIB::ipInDelivers.0 = Counter32: 44984
IP-MIB::ipOutRequests.0 = Counter32: 0
IP-MIB::ipOutDiscards.0 = Wrong Type (should be Counter32): INTEGER: 0
IP-MIB::ipOutNoRoutes.0 = Wrong Type (should be Counter32): INTEGER: 0
IP-MIB::ipReasmTimeout.0 = INTEGER: 0 seconds
IP-MIB::ipReasmReqds.0 = Wrong Type (should be Counter32): INTEGER: 0
IP-MIB::ipReasmOKs.0 = Wrong Type (should be Counter32): INTEGER: 0
IP-MIB::ipReasmFails.0 = Wrong Type (should be Counter32): INTEGER: 0
IP-MIB::ipFragOKs.0 = Wrong Type (should be Counter32): INTEGER: 0
IP-MIB::ipFragFails.0 = Wrong Type (should be Counter32): INTEGER: 0
IP-MIB::ipFragCreates.0 = Wrong Type (should be Counter32): INTEGER: 0
IP-MIB::ipAdEntAddr.192.168.58.96 = IpAddress: 192.168.58.96
IP-MIB::ipAdEntIfIndex.192.168.58.96 = INTEGER: 1
IP-MIB::ipAdEntNetMask.192.168.58.96 = IpAddress: 255.255.255.0
IP-MIB::ipAdEntBcastAddr.192.168.58.96 = INTEGER: 1
IP-MIB::ipAdEntReasmMaxSize.192.168.58.96 = INTEGER: 0
IP-MIB::icmpInMsgs.0 = Counter32: 0
IP-MIB::icmpInErrors.0 = Wrong Type (should be Counter32): INTEGER: 0
IP-MIB::icmpInDestUnreachs.0 = Counter32: 0
IP-MIB::icmpInTimeExcds.0 = Counter32: 0
IP-MIB::icmpInParmProbs.0 = Counter32: 0
IP-MIB::icmpInSrcQuenchs.0 = Counter32: 0
IP-MIB::icmpInRedirects.0 = Counter32: 0
IP-MIB::icmpInEchos.0 = Counter32: 0
IP-MIB::icmpInEchoReps.0 = Counter32: 0
IP-MIB::icmpInTimestamps.0 = Counter32: 0
IP-MIB::icmpInTimestampReps.0 = Wrong Type (should be Counter32): INTEGER: 0
IP-MIB::icmpInAddrMasks.0 = Wrong Type (should be Counter32): INTEGER: 0
IP-MIB::icmpInAddrMaskReps.0 = Wrong Type (should be Counter32): INTEGER: 0
IP-MIB::icmpOutMsgs.0 = Counter32: 0
IP-MIB::icmpOutErrors.0 = Wrong Type (should be Counter32): INTEGER: 0
IP-MIB::icmpOutDestUnreachs.0 = Counter32: 120
IP-MIB::icmpOutTimeExcds.0 = Wrong Type (should be Counter32): INTEGER: 0
IP-MIB::icmpOutParmProbs.0 = Wrong Type (should be Counter32): INTEGER: 0
IP-MIB::icmpOutSrcQuenchs.0 = Wrong Type (should be Counter32): INTEGER: 0
IP-MIB::icmpOutRedirects.0 = Wrong Type (should be Counter32): INTEGER: 0
IP-MIB::icmpOutEchos.0 = Wrong Type (should be Counter32): INTEGER: 0
IP-MIB::icmpOutEchoReps.0 = Counter32: 0
IP-MIB::icmpOutTimestamps.0 = Wrong Type (should be Counter32): INTEGER: 0
IP-MIB::icmpOutTimestampReps.0 = Wrong Type (should be Counter32): INTEGER: 0
IP-MIB::icmpOutAddrMasks.0 = Wrong Type (should be Counter32): INTEGER: 0
IP-MIB::icmpOutAddrMaskReps.0 = Wrong Type (should be Counter32): INTEGER: 0
UDP-MIB::udpInDatagrams.0 = Counter32: 24553
UDP-MIB::udpNoPorts.0 = Counter32: 3526
UDP-MIB::udpInErrors.0 = Counter32: 13349
UDP-MIB::udpOutDatagrams.0 = Counter32: 494
..0==/--\==0....
....../___\........
......_| |_.........
Eric Norum
[email protected]
Trouble with OID name using devsnmp. Nicoletta Petrella
Prev: Trouble with OID name using devsnmp. Nicoletta Petrella
Next: Re: Trouble with OID name using devsnmp. John A. Priller
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024
ANJ, 17 Dec 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
