Tonia, Yes, as J. Lewis Muir said: if you move the order the fields in the structure, might shed some light on things.Remember, ARM is MUCH more restrictive in alignment than Intel. From the ARM Reference Manual: (A2.8) Prior to ARMv6, doubleword (
LDRD / STRD ) accesses to memory, where the a
ddress is not doubleword-aligned, are UNPREDICTABLE
. Also, data accesses to non-aligned word an d halfword data are treated as aligned from
the memory interface perspective. That is: • the address is treated as truncat ed, with address bits[1:0] treate
d as zero for word accesses, and address bit[0] treated as
zero for halfword accesses. • load single word ARM instructions are architecturally defined to ro
tate right the wo rd-aligned data transferred by a non word-aligned address one, two
or three bytes depending on the value of the two least significant address bits.
• alignment checking is defined fo r implementations supporting a Syst em Control coprocessor using
the A bit in CP15 register 1As previously suggested, printout the "thing" being pointed to (message) at point A (where correct) then again at point B (where incorrect) and look for differences. The Linux 2.6.10 is a very old kernel. Might be some library/kernel issue as well. . . Is this structure "statically" allocated (i.e. not on the stack)? Also, check the compiler directives w.r.t. alignment issues. Your idea of a test program is also very good. Regards, Stephen Beckwith On Tue, May 6, 2014 at 10:53 AM, J. Lewis Muir <[email protected]> wrote: On 5/6/14, 9:41 AM, Tonia Batten wrote:
ANJ, 17 Dec 2015 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
