If I were trying to access the same object on an x86 and an ARM then indeed packing could be an issue. But I am NOT trying to access the object on 2 different architectures. It is a simple structure that is being accessed only on the ARM. There is no need to worry about whether a double is the same size on the 2 architectures, it is only required that the ARM be internally consistent, which it certainly should be.
The queue is a very well tested code in asynManager, used on ARM and dozens of other architectures with no problems. It is not a fixed size queue.
Sent: Tuesday, May 06, 2014 7:04 AM
To: Mark Rivers
Cc: J. Lewis Muir; Tonia Batten; [email protected]
Subject: Re: Newport XPS-Q8 and Motor Record - armv5teb architecture
You miss my point:
Since the issue is between two different ISA's (x86, which is byte addressable memory vs. ARM v5 which is 4 byte (32 bit) addressable memory), you WILL have alignment issues in certain cases. In addition, supporting libraries and other code may have issues with the "native types" - make sure the double is the same width (in bytes) on each architecture.
Another idea: Dump (in hex) the message pointed to by the pmsg pointer.
you mention a Queue - if you're doing memory copies (??) then size becomes an issue. The other possibility is,again, due to a size issue, there is a clash between this structure and another one next to it and the dvalue is getting overwritten.
Stephen Beckwith
On Tue, May 6, 2014 at 7:18 AM, Mark Rivers <[email protected]<mailto:[email protected]>> wrote:
> Could be padding issue in how the compilers for different ISA handle the alignment.
That should not be an issue because the structure is only being accessed by code using the same definition of the structure. The structure is written to in one function and read from in another function in the same source code module. Packing should be irrelevant.
> Does the ARM compiler being used has proper library support for double?
It certainly appears to. The double values are being computed correctly in the motor record, and they are being printed correctly in this device support code.
From: Stephen Beckwith [[email protected]<mailto:[email protected]>]
Sent: Monday, May 05, 2014 10:00 PM
To: J. Lewis Muir
Cc: Mark Rivers; Tonia Batten; [email protected]<mailto:[email protected]>
Intel is Little Endian - ARM can be either - how is the ARMv5 setup? Big Endian or Little Endian?
What OS are you dealing with? What compiler?
What happens if you move the double and int? Could be padding issue in how the compilers for different ISA handle the alignment. Is the Intel a 64bit CPU? (I know ARMv5 is not, that’s a “StrongArm” variant basically or Marvell. . .
Stephen Beckwith
On Sat, May 3, 2014 at 8:39 PM, J. Lewis Muir <[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>> wrote:
On 5/3/14, 5:32 PM, Mark Rivers wrote:
> Any idea how this could happen?
Hi, Mark.
Compiler bug? Maybe try turning off all optimizations?
Lewis
- Re: Newport XPS-Q8 and Motor Record - armv5teb architecture Stephen Beckwith
- Re: Newport XPS-Q8 and Motor Record - armv5teb architecture Jens Eden
- RE: Newport XPS-Q8 and Motor Record - armv5teb architecture Mark Rivers
- Re: Newport XPS-Q8 and Motor Record - armv5teb architecture J. Lewis Muir
<2014>
<2014>
