Intel is Little Endian - ARM can be either - how is the ARMv5 setup? Big Endian or Little Endian? What OS are you dealing with? What compiler? What happens if you move the double and int? Could be padding issue in how the compilers for different ISA handle the alignment. Is the Intel a 64bit CPU? (I know ARMv5 is not, that’s a “StrongArm” variant basically or Marvell. . .
Does the ARM compiler being used has proper library support for double? Stephen Beckwith
- RE: Newport XPS-Q8 and Motor Record - armv5teb architecture Mark Rivers
- RE: Newport XPS-Q8 and Motor Record - armv5teb architecture Tonia Batten
- Re: Newport XPS-Q8 and Motor Record - armv5teb architecture J. Lewis Muir
QE Framework 2.8.1 Ricardo Fernandes
Re: Newport XPS-Q8 and Motor Record - armv5teb architecture Torsten Bögershausen
<2014>
<2014>
ANJ, 17 Dec 2015 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
