1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: QE Framework 2.8.1
Date: Mon, 5 May 2014 08:09:51 +0000
Hello all,
We would like to announce the release of a new version (2.8.1) of the QE Framework. It can be found here:
   http://sourceforge.net/projects/epicsqt/files
This new version has the following changes since 2.7.1 (please refer to the release notes for a comprehensive report):
Customisation:
- widget/application interaction
- externalisation of widget controls
- QEGui customisation
New widgets/classes:
- QEUtilities
- QEStripChart/QEPlotter
- QEResizeableFrame
- QEArchiveNameSearch
- QEGeneralEdit
- QEDialog
Enhanced widgets/classes:
- QEImage (areaDetector integration)
Deprecation:
Removed deprecated QCa widgets. All deprecated widgets were only thin wrappers around current QE widgets. For example,
QCaLabel was implemented using QELabel. Any code or .ui files referencing deprecated QCa widgets can be modified to use
the current version by simply renaming any widget from QCa<name>Plugin to QE<name>.
Please feel free to ask the development team for additional details.
Ricardo Fernandes.
Prev: Re: Newport XPS-Q8 and Motor Record - armv5teb architecture J. Lewis Muir
Next: Re: Newport XPS-Q8 and Motor Record - armv5teb architecture Stephen Beckwith
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: RE: Newport XPS-Q8 and Motor Record - armv5teb architecture Mark Rivers
Next: Trouble with OID name using devsnmp. Nicoletta Petrella
ANJ, 17 Dec 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
