The problem Hinko describes is different. That problem is just that the Andor images are 16-bit and the default ImageJ brightness and contrast control does not display them correctly. Just press Cntl+Shift+C to bring up the brightness and contrast control and hit Auto and it will display correctly. Or you can just use the brightness and contrast sliders.
From: [email protected] [[email protected]] on behalf of Hinko Kocevar [[email protected]]
Sent: Friday, May 02, 2014 2:02 PM
To: Zachary Brown
Cc: [email protected]
Subject: Re: Point Grey Flea3 areaDetector ImageJ Viewer Problems
When testing Andor camera couple of days ago and also using ImageJ encountered the similar problem. The ImageJ would show the image but it was all white. After some clicking around the ImageJ I’ve managed to get the data visualised by 1) setting some LUT and 2) invoking the dialog for edit LUT (I do not have the ImageJ at hand to give you exact path in the menu to reach this). As soon as the dialog would popup I could see the image.
Of course EPICS_CA_MAX_ARRAY_BYTES was set to a high value, too.
HTH,HInko
On 02 May 2014, at 20:00, Zachary Brown <[email protected]<mailto:[email protected]>> wrote:
From more testing:
A camonitor on PG1:image1:ArrayData shows that the values in the array are changing as the camera is moved around, so the array is getting updated.
ImageJ still shows a zero-value array. The image shown from the plugin is 1280x1024 (8-bit) as it should be, but no pixel values.
The Array Counter in for the StdArray increases with the image count, but I did notice that the Unique ID for each array does not change (not sure if this is relevent, have not paid attention to this parameter before).
-Zachary Brown, John Dobbins
On Fri, May 2, 2014 at 1:02 PM, Zachary Brown <[email protected]<mailto:[email protected]>> wrote:
Hello,
I am using the new Point Grey pre-built in windows 7 x64. I am having issues streaming the images to the ImageJ areaDetector plugin.
I am able to acquire images in all image modes (single, multiple, continuous) and save the images using the TIFF plugin, but the NDStdArrays plugin does not seem to be getting any data, so the callbacks do not update, so the ImageJ plugin does not stream.
PG1:cam1:ArrayCallbacks is set to Enable
PG1:image1:EnableCallbacks is set to Enable
If any more information would be helpful, please contact me, thank you,
-ZB
- Re: Point Grey Flea3 areaDetector ImageJ Viewer Problems Zachary Brown
- Re: Point Grey Flea3 areaDetector ImageJ Viewer Problems Hinko Kocevar
RE: Point Grey Flea3 areaDetector ImageJ Viewer Problems Mark Rivers
RE: Point Grey Flea3 areaDetector ImageJ Viewer Problems John Dobbins
<2014>
RE: Newport XPS-Q8 and Motor Record - armv5teb architecture Mark Rivers
<2014>
