1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: [CSS] freeze and lost running PV in Boy Screens
To: [email protected]
Date: Wed, 30 Apr 2014 23:33:57 +0200 (CEST)
Hello to everyone,
using the CSS GUI to control EPICS variables provided by a VME system, i
saw "PV Disconnection" on the screen. On the VxWorks EPICS shell i found
this message:
A call to 'assert(ev_que->evque[ev_que->putix] == EVENTQEMPTY)'
    by thread 'CAS-client' failed in ../dbEvent.c line 701.
EPICS Release EPICS R3.14.12.4 $Date: Mon 2013-12-16 15:51:45 -0600$.
Local time is 2014-04-29 10:05:52.897742610 MET
Please E-mail this message to the author or to [email protected]
Calling epicsThreadSuspendSelf()
Thread CAS-client (0x6a2910) suspended
The VME System has 2 different kind of acquisition boards, one for "slow
acquisition" and one for "fast acquisition". On the CSS side, i have a
main panel for the sub-system controlled and 2 popup windows, one for
each acquisition.
I tried some tests with this system (VME+CSS), and after some
investigation i've understood and observed the following points:
* when i open the popup related to the slow acquisition OR to the fast
acquisition, everything works correctly
* when i open one popup, i close it and i open the other one, it seem to
work correctly
* when i open the slow popup and after open the fast without closing the
previous one, in the slow acquisition i lost the connection with all the
PVs (freezing values AND/OR loosing connection). If i close the "fast"
popup, i return in the normal situation
* during this tests i checked through common epics command line tools
the PVs status and they continuously running without problems (no
problems with the VME IOC)
* i also tried to change the CSS version, using all the versions
available from SNS site (BASIC versions from 3.2.1 to 3.2.16) but i had
always the same situation.
Has someone seen this kind of behavior or this kind of messages before?
An indication for a point to start a deep investigation will be
appreciated.
Thanks in advance for any help
- Maurizio
~~ Maurizio Montis - Control System Engineer ~~
   mobile: +39 3408428089
   mail: [email protected]
   skype: maurizio_montis
Istituto Nazionale di Fisica Nucleare - Laboratori Nazionali di Legnaro
   V.le dell'Universita', 2
   35020 LEGNARO (PD) - ITALY
RE: [CSS] freeze and lost running PV in Boy Screens Hill, Jeff
Re: [CSS] freeze and lost running PV in Boy Screens Kasemir, Kay
Prev: Re: asyn vxi11 problem Dirk Zimoch
Next: RE: [CSS] freeze and lost running PV in Boy Screens Hill, Jeff
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: [SPAM] RE: cannot run medm rightly on ubuntu 13.04 ahwwq
ANJ, 17 Dec 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
