Hi LIU Ping,
Looks like the line:
ipacAddAvme96XX("0x2000,5 A=2,800000")
I think that you just need to change the second parameter to a 4 since the
carrier only has 4 slots.
should be:
ipacAddAvme96XX("0x2000,4 A=2,0x800000")
This means that your carrier A16 base address is 0x2000, you have 4 IP slots,
slot A is configured for 2 MB of memory space, and that your soft glue address
is 0x800000. Then you should see something like this from ipacReport:
C0 S1 : 0xb3/0x2a
ID = 0xd2006180, I/O = 0xd2006100
Also I think you should move your ipacReport line to after where you load soft
glue since this actually loads the code into the FPGA on the IP module. this
way ipacReport is more useful.
I have attached the Acromag carrier user manual for yous well. It looks like
your address jumpers are correct.
See if that helps,
Marty
On 04/28/2014 08:55 PM, LiuP wrote:
With the carrier board AVME9670 and one IP card IP-EP201, I try to run the
application of softGlue.
The software version:
EPICS_BASE=/BLC/epics/base3.14.12
SOFTGLUE=$(SUPPORT)/softGlue-2-3
ASYN=$(SUPPORT)/asyn-4-21
IPAC=$(SUPPORT)/ipac-2-11
BUSY=$(SUPPORT)/busy-1-4
The output of st.cmd, the error is remarked in red:
Executing startup script /home/blctrl/Acromag_EP201/iocBoot/iocEP201/st.cmd ...
## Example vxWorks startup file
## The following is needed if your board support package doesn't at boot time
## automatically cd to the directory containing its startup script
cd "/home/blctrl/Acromag_EP201/iocBoot/iocEP201"
value = 0 = 0x0
< cdCommands
startup = "/home/blctrl/Acromag_EP201/iocBoot/iocEP201"
new symbol "startup" added to symbol table.
startup = 0x1ef26cd0: value = 519204080 = 0x1ef26cf0 = startup + 0x20
putenv("ARCH=vxWorks-ppc604_long")
value = 0 = 0x0
putenv("IOC=iocEP201")
value = 0 = 0x0
top = "/home/blctrl/Acromag_EP201"
new symbol "top" added to symbol table.
top = 0x1ef26990: value = 519203792 = 0x1ef26bd0 = top + 0x240
putenv("TOP=/home/blctrl/Acromag_EP201")
value = 0 = 0x0
topbin = "/home/blctrl/Acromag_EP201/bin/vxWorks-ppc604_long"
new symbol "topbin" added to symbol table.
topbin = 0x1ef268c0: value = 519203040 = 0x1ef268e0 = topbin + 0x20
support = "/BLC/epics/support"
new symbol "support" added to symbol table.
support = 0x1ef26840: value = 519202912 = 0x1ef26860 = support + 0x20
putenv("SUPPORT=/BLC/epics/support")
value = 0 = 0x0
softglue = "/BLC/epics/support/softGlue-2-3"
new symbol "softglue" added to symbol table.
softglue = 0x1ef26760: value = 519202688 = 0x1ef26780 = softglue + 0x20
putenv("SOFTGLUE=/BLC/epics/support/softGlue-2-3")
value = 0 = 0x0
asyn = "/BLC/epics/support/asyn-4-21"
new symbol "asyn" added to symbol table.
asyn = 0x1ef26660: value = 519202432 = 0x1ef26680 = asyn + 0x20
putenv("ASYN=/BLC/epics/support/asyn-4-21")
value = 0 = 0x0
asynbin = "/BLC/epics/support/asyn-4-21/bin/vxWorks-ppc604_long"
new symbol "asynbin" added to symbol table.
asynbin = 0x1ef26540: value = 519202144 = 0x1ef26560 = asynbin + 0x20
ipac = "/BLC/epics/support/ipac-2-11"
new symbol "ipac" added to symbol table.
ipac = 0x1ef264c0: value = 519202016 = 0x1ef264e0 = ipac + 0x20
putenv("IPAC=/BLC/epics/support/ipac-2-11")
value = 0 = 0x0
busy = "/BLC/epics/support/busy-1-4"
new symbol "busy" added to symbol table.
busy = 0x1ef263c0: value = 519201760 = 0x1ef263e0 = busy + 0x20
putenv("BUSY=/BLC/epics/support/busy-1-4")
value = 0 = 0x0
epics_base = "/BLC/epics/base"
new symbol "epics_base" added to symbol table.
epics_base = 0x1ef262d0: value = 519201520 = 0x1ef262f0 = epics_base + 0x20
putenv("EPICS_BASE=/BLC/epics/base")
value = 0 = 0x0
epics_basebin = "/BLC/epics/base/bin/vxWorks-ppc604_long"
new symbol "epics_basebin" added to symbol table.
epics_basebin = 0x1ef261e0: value = 519201280 = 0x1ef26200 = epics_basebin + 0x20
#< ../nfsCommands
cd topbin
value = 0 = 0x0
## You may have to change EP201 to something else
## everywhere it appears in this file
ld 0,0, "EP201.munch"
BSP routine sysAtReboot() not found, epicsExit() will not be
called by reboot. For reduced functionality, call
rebootHookAdd(epicsExitCallAtExits)
value = 519203312 = 0x1ef269f0 = top + 0x60
cd top
value = 0 = 0x0
dbLoadDatabase "dbd/EP201.dbd"
value = 0 = 0x0
EP201_registerRecordDeviceDriver pdbbase
value = 0 = 0x0
## Load record instances
#dbLoadTemplate "db/user.substitutions"
#dbLoadRecords "db/dbSubExample.db", "user=blctrl"
## Set this to see messages from mySub
#mySubDebug = 1
## Run this to trace the stages of iocInit
#traceIocInit
value = 0 = 0x0
ipacReport(2)
IP Carrier 0: Acromag AVME-96xx, 4 slots
C0 S0 : No Module
ID = 0xf0f02080, I/O = 0xf0f02000, Mem = 0xf0700000
C0 S1 : No Module
ID = 0xf0f02180, I/O = 0xf0f02100
C0 S2 : No Module
ID = 0xf0f02280, I/O = 0xf0f02200
C0 S3 : No Module
ID = 0xf0f02380, I/O = 0xf0f02300
value = 0 = 0x0
drvIP_EP201Debug=1
drvIP_EP201Debug = 0x1ebfe7e4: value = 1 = 0x1
initIP_EP200_FPGA(0, 0, "$(SOFTGLUE)/softGlueApp/Db/SoftGlue_2_2.hex")
initIP_EP200_FPGA: bad carrier or slot
value = -1 = 0xffffffff
cd startup
value = 0 = 0x0
# < softGlue.cmd
iocInit
Starting iocInit
## EPICS R3.14.12.2 $Date: Mon 2011-12-12 14:09:32 -0600$
## EPICS Base built Apr 9 2012
WARNING: OS Clock time was read before being set.
Using 1990-01-02 00:00:00.000000 UTC
value = 0 = 0x0
## Start any sequence programs
#seq &sncExample, "user=blctrl"
Done executing startup script /home/blctrl/Acromag_EP201/iocBoot/iocEP201/st.cmd
Why no module is been found?
No user manual in the package of acromag hardware, and also fail to download the
manual.
Without documents, how can I make sure the carrier board has configured successful?
The parameters of ipacAddAvme96XX("0x2000,5 A=2,800000") is imitated according
to the drvXy9660.c
Any suggest to me is welcome!
LIU Ping
Beamline Contrl Group, SSRF
No. 239 Zhangheng Road, Pudong, Shanghai
AVME9670_UserManual.pdf
Description: Adobe PDF document
- Acromag avme9670 LiuP
Re: asyn vxi11 problem Dirk Zimoch
Re: PCMON segmentation fault Nicoletta Petrella
<2014>
Re: Acromag avme9670 LiuP
<2014>
