Hi Dave,
You are doing dynamic builds using DLLs on Windows. In areaDetector 1-9-1 and earlier that did not work well if at all.
If you use 1-9-1 then you should use STATIC__BUILD=YES and SHARED_LIBRARIES=NO.
I would suggest upgrading to areaDetector 2-0 which does support dynamic builds on Windows. This support for dynamic builds is documented in the RELEASE.md file in the ADCore module in github.com/areaDetector<http://github.com/areaDetector>.
Sent from my iPhone
On Apr 26, 2014, at 1:58 AM, "David Reid" <[email protected]<mailto:[email protected]>> wrote:
Hi everyone…
I’m trying to build Area Detector (along with asyn, autosave, busy, calc, and sscan) from the SynApps release on windows-x64, and have run into a problem. The error is:
LINK : warning LNK4098: defaultlib 'LIBCMT' conflicts with use of other libs; use /NODEFAULTLIB:library
Generating code
Finished generating code
LIBCMT.lib(timeset.obj) : error LNK2005: __daylight already defined in MSVCRT.lib(MSVCR120.dll)
LIBCMT.lib(timeset.obj) : error LNK2005: __timezone already defined in MSVCRT.lib(MSVCR120.dll)
NeXus.dll : fatal error LNK1169: one or more multiply defined symbols found
make[4]: *** [NeXus.dll] Error 1169
make[4]: Leaving directory `c:/epics/synApps_5_7/support/areaDetector-1-9-1/ADApp/nexusSrc/O.windows-x64'
make[3]: *** [install.windows-x64] Error 2
make[3]: Leaving directory `c:/epics/synApps_5_7/support/areaDetector-1-9-1/ADApp/nexusSrc'
make[2]: *** [nexusSrc.install] Error 2
make[2]: Leaving directory `c:/epics/synApps_5_7/support/areaDetector-1-9-1/ADApp'
make[1]: *** [ADApp.install] Error 2
make[1]: Leaving directory `c:/epics/synApps_5_7/support/areaDetector-1-9-1'
make: *** [c:\epics\synApps_5_7\support/areaDetector-1-9-1.install] Error 2
Thanks for any help….
Dave
David Reid
Software Engineer, Behavior
<image001.png>
www.alleninstitute.org<http://www.alleninstitute.org/>
- Area Detector build issues... David Reid
PCMON segmentation fault Nicoletta Petrella
<2014>
<2014>
