1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Help about creat Archive Engine
To: 陈志华 <[email protected]>
Date: Tue, 22 Apr 2014 11:44:00 -0400
Hi:
The archive engine currently uses the vtype.pv layer, because that lowered its CPU load and memory usage compared to the PVManager.
… but doesn't support "sim" type PVs, as the error message states.
So the archive engine is currently only useful to write data from real PVs, not simulated data.
-Kay
On Apr 21, 2014, at 10:30 PM, 陈志华 <[email protected]<mailto:[email protected]>> wrote:
Dear
         I'm having trouble during the installation archive engine.
using the default plugin_customizationl.ini and preferences.ini
  Download the Eclipse for RCP and RAP Developers
                                     sns_css_src_3.2.16
                                     java version "1.7.0_25"
Java(TM) SE Runtime Environment (build 1.7.0_25-b17)
Java HotSpot(TM) 64-Bit Server VM (build 23.25-b01, mixed mode)
2014-04-22 10:21:23.237 CONFIG [Thread 1] org.csstudio.vtype.pv.internal.Activator (start) - PV prefix ca provided by JCA in org.csstudio.vtype.pv
2014-04-22 10:21:23.242 CONFIG [Thread 1] org.csstudio.vtype.pv.internal.Activator (start) - PV prefix loc provided by Local in org.csstudio.vtype.pv
2014-04-22 10:21:23.244 CONFIG [Thread 1] org.csstudio.vtype.pv.internal.Activator (start) - Default PV type ca
2014-04-22 10:21:23.247 INFO [Thread 1] org.csstudio.archive.engine.Application (start) - Archive Engine 3.3.0.201404171029
2014-04-22 10:21:23.424 INFO [Thread 1] org.csstudio.archive.engine.server.EngineServer (<init>) - Engine HTTP Server on http://localhost:4812/main
2014-04-22 10:21:23.425 INFO [Thread 1] org.csstudio.archive.engine.Application (start) - Reading configuration 'Demo'
2014-04-22 10:21:23.858 INFO [Thread 1] org.csstudio.archive.engine.model.ArchiveChannel (<init>) - No known last value for freddy
2014-04-22 10:21:23.859 INFO [Thread 1] org.csstudio.archive.engine.model.ArchiveChannel (<init>) - No known last value for sim://noiseWaveform(0,10,100,10)
2014-04-22 10:21:23.865 INFO [Thread 1] org.csstudio.archive.engine.Application (start) - Read configuration: 3 channels in 0.437 seconds
2014-04-22 10:21:23.865 INFO [Thread 1] org.csstudio.archive.engine.Application (start) - Running, CA addr list: 127.0.0.1
2014-04-22 10:21:23.868 INFO [Thread 28] org.csstudio.archive.engine.model.WriteThread (run) - WriteThread starts
2014-04-22 10:21:23.929 CONFIG [Thread 1] org.csstudio.vtype.pv.jca.JCAContext (<init>) - Using Pure Java CAJ
2014-04-22 10:21:24.239 SEVERE [Thread 1] org.csstudio.archive.engine.Application (start) - Unhandled Main Loop Error
java.lang.Exception: sim://noiseWaveform(0,10,100,10) has unknown PV type 'sim'
         at org.csstudio.vtype.pv.PVPool.createPV(PVPool.java:127)
         at org.csstudio.vtype.pv.PVPool.getPV(PVPool.java:109)
         at org.csstudio.archive.engine.model.ArchiveChannel.start(ArchiveChannel.java:200)
         at org.csstudio.archive.engine.model.ArchiveGroup.start(ArchiveGroup.java:136)
         at org.csstudio.archive.engine.model.EngineModel.start(EngineModel.java:297)
         at org.csstudio.archive.engine.Application.start(Application.java:193)
         at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:196)
         at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:110)
         at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:79)
         at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:354)
         at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:181)
         at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
         at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
         at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
         at java.lang.reflect.Method.invoke(Method.java:606)
         at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:636)
         at org.eclipse.equinox.launcher.Main.basicRun(Main.java:591)
         at org.eclipse.equinox.launcher.Main.run(Main.java:1450)
Help about creat Archive Engine 陈志华
Prev: Help about creat Archive Engine 陈志华
Next: multiple threads and ca_attach_context Al Honey
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024
ANJ, 17 Dec 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
