1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: =?gb18030?b?UmU6UkU6IEhvdyB0byBzdG9wIGFjcXVpcmUgaW4g?==?gb18030?b?RGJsQ29ycmVsYXRpb24gTW9kZSBmb3IgTWFyQ0NE?==?gb18030?b?IGluQXJlYURldGVjdG9yCW1vZHVsZQ==?=
To: "=?gb18030?b?cml2ZXJz?=" <[email protected]>, "=?gb18030?b?dGVjaC10YWxr?=" <[email protected]>
Date: Thu, 17 Apr 2014 12:55:03 +0800
Dear Mark,
Thank you for your work! It worked correctly in our beamline and it only couldn't stop acquire in DblCorrelation Mode compleltely!
With best regards,
Zhou Ping
SAXS Beamline, SINAP, Chinese Academy of Sciences
Address:239 ZhangHeng Road,Pudong District,Shanghai,201203,P.R.China
Tel:86-21-33932019    Mobile: 86-18116357596
Email:[email protected]
------------------ Original ------------------
Date:  Wed, Apr 16, 2014 10:52 PM
To:  "周平"<[email protected]>; "tech-talk"<[email protected]>;
Subject:  RE: How to stop acquire in DblCorrelation Mode for MarCCD inAreaDetector module
Just a quick follow-up.  I have reproduced the problem, and indeed I found I cannot even stop a normal (not double-correlation) image with long exposure times without introducing problems.
I need access to a detector to debug this, and that will have to wait till after May 4.
-----Original Message-----
From: [email protected] [mailto:[email protected]] On Behalf Of Mark Rivers
Sent: Wednesday, April 09, 2014 6:24 AM
To: 周平; tech-talk
Subject: RE: How to stop acquire in DblCorrelation Mode for MarCCD in AreaDetector module
Hi Zhou Ping,
I was not aware of this problem.  I will test it today and see if I can reproduce it and find a solution.
From: [email protected] [[email protected]] on behalf of 周平 [[email protected]]
Sent: Wednesday, April 09, 2014 2:38 AM
To: tech-talk
Subject: How to stop acquire in DblCorrelation Mode for MarCCD in AreaDetector module
Hi All,
The detector of our beamline is MarCCD and the type is SX165. It worked in  areaDetectorR1-9-1 Module correctly.  The parameters were as follows:
    ADFrameType = DblCorrelation;
    ADImageMode = Single;
    marCCDStability = 0;
    marCCDOverlap = Sequential;
    In this condition, I found it can't stop acquire completely when it was acquiring. It can only stop front half acquire time and the back time can't stopped. For example, if I set the acquire time = 100s, then I clicked the start button to start acquire. If I want to stop acquire when it had acquired 20s for front half the nominal acquisition time, I clicked the stop button to stop it.  And then I found it still acquired in the next half the nominal acquisition time which was 50s. It couldn't be stopped completely!
    If I set ADFrameType to Normal, it could be stopped quickly. But the background noise was too large in this mode so I set ADFrameType to DblCorrelation for use.
    Is there a way to solve this problem?
    Thanks!
With best regards,
Zhou Ping
How to stop acquire in DblCorrelation Mode for MarCCD in AreaDetector module =?gb18030?b?1tzGvQ==?=
RE: How to stop acquire in DblCorrelation Mode for MarCCD in AreaDetector module Mark Rivers
Prev: Re: EPICS support plans for Solaris Bill Lavender
Next: CSS BOY Setting value of enum record in a python script giles.knap
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: RE: How to stop acquire in DblCorrelation Mode for MarCCD in AreaDetector module Mark Rivers
Next: EDM - where to find widget "Variable Scale Bar" Joachim Rahn
ANJ, 17 Dec 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
