we have a quite large number of BOY OPI-s that use Jython scripts. These
Jython scripts
use "org.csstudio.utility.pv", namely PVFactory, so they contain the
following line:
from org.csstudio.utility.pv import PVFactory
Until now we have been using basic EPICS CSS 3.1.7 build from SNS , and
now we would
like to use the recent version 3.2.16. But what happens now with that
version is that Jython fails
to find the "org.csstudio.utility.pv" on the line shown above. That
plugin is incuded in the plugin
directory, and when I explicitly append the jar-file to the sys.path,
then the scripts work.
At this time I do not want to go into each script file and add a line to
append the jar
file. Instead, I was wandering if I can recompile EPICS CSS from SNS
source in such a way that I do
not need to specify the "org.csstudio.utility.pv" path myself in the
scripts. Just getting the source for 3.2.26
and making the "org.csstudio.basic.epics.product" produces the same
result. Is there something
simple that I need to change in Eclipse when building the product to
have that jar-file included in the list
when Jython loads?
Hovanes Egiyan.
- PVManager Re: importing "org.csstudio.utility.pv" in BOY Jython scripts Kasemir, Kay
RE: Streamdevice 2.6 autoconnection failure using drvAsynSerialPort Mazanec Tomáš
<2014>
Re: Problem with UInt32Digital in Asyn Wilkins, Stuart
<2014>
ANJ, 17 Dec 2015 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
