Am Montag, 14. April 2014, 17:34:27 schrieb Graber, Tim:
> Hi Ben-
> I added a few statements to the code in addition to the patch to print out
> more information. The source codes are attached as well.
The are are no significant difference between your pvSync.i and mine, so I
guess we can exclude CPP from the list of suspects.
> When the build
> gets to the point where it is going to print the offending scope->type, the
> process hangs on the function:
> report_at_expr(scope, "scope->type == %d\n", scope->type);
> and I can't ctrl-c out of it. I actually have to kill the Cygwin window and
> start over.
That strongly suggests the 'scope' pointer is corrupt. I guess you will have
to start it with a debugger, as Eric described. (Thanks, Eric, for the
suggestion.)
You could also wait until I get a 64 Bit Windows VM so I can debug this
myself. I ordered one today, but it could take a few days until I can get my
hands on it.
Cheers
Ben
> Here is the part of the analysis.c code that I changed:
> switch(scope->type)
> case D_PROG:
> return scope->prog_defns;
> case D_SS:
> return scope->ss_defns;
> case D_STATE:
> return scope->state_defns;
> case D_WHEN:
> return scope->when_defns;
> case D_ENTRY:
> return scope->entry_defns;
> case D_EXIT:
> return scope->exit_defns;
> case S_CMPND:
> return scope->cmpnd_defns;
> default:
> report("In default, line = 209\n");
> report_at_expr(scope, "offending scope->type == %d\n", scope->type);
> assert(impossible);
> return NULL;
> Here is the output from the build:
> ../../../bin/cygwin-x86_64/snc.exe +m -i pvSync.i -o pvSync.c.tmp
> ../pvSync.st:7: scope->type == 6
> ../pvSync.st:33: scope->type == 2
> ../pvSync.st:41: scope->type == 7
> ../pvSync.st:42: scope->type == 8
> ../pvSync.st:43: scope->type == 11
> ../pvSync.st:51: scope->type == 7
> ../pvSync.st:52: scope->type == 8
> ../pvSync.st:54: scope->type == 11
> ../pvSync.st:64: scope->type == 7
> ../pvSync.st:65: scope->type == 8
> ../pvSync.st:66: scope->type == 11
> ../pvSync.st:75: scope->type == 8
> ../pvSync.st:76: scope->type == 11
> ../pvSync.st:80: scope->type == 25
> Tim
> -----Original Message-----
> From: Benjamin Franksen [mailto:[email protected]]
> Sent: Monday, April 14, 2014 10:31 AM
> To: Mark Rivers
> Cc: Graber, Tim; [email protected]
> Subject: Re: Sequencer build problem cygwin64
> Oops, no core file. That makes things more difficult.
> Can you apply this patch:
> diff -rN -u old-branch-2-1/src/snc/analysis.c new-
--- old-branch-2-1/src/snc/analysis.c
> 2014-04-14 17:30:40.000000000 +0200
> +++ new-branch-2-1/src/snc/analysis.c 2014-04-14 17:30:40.000000000
> +0200
> @@ -205,6 +205,7 @@
> case S_CMPND:
> default:
> + report_at_expr(scope, "offending scope->type == %d\n",
> scope->type);
> assert(impossible); return NULL;
> and then run again and send the output?
> Cheers
> Ben
> On Monday, April 14, 2014 15:22:13 Mark Rivers wrote:
> > The last time I checked on Cygwin it did not produce useful core
> > files, so gdb could not be used with them.
> > Maybe it has improved since I last tried it?
> > Mark
> > From: [email protected]
> > [mailto:[email protected]] On Behalf Of Benjamin Franksen
> Sent: Monday, April 14, 2014 10:15 AM
> > To: Graber, Tim; [email protected]
> > Hi Tim
> > can you send me the original pvSync.i? Maybe there is a problem with
> > the
> C preprocessor on your platform.
> > Also, can you use gdb to analyse the core for the aborted snc run?
> > Start
> it like
> > gdb bin/cygwin-x86_64/snc.exe test/validate/O.cygwin-x86_64/core
> > and enter
> > backtrace
> > then send me the output.
> > Thanks
> > Ben
> > On Monday, April 14, 2014 02:51:42 Graber, Tim wrote:
> > > Hi Ben-
> > > I did a bit more debugging and found the point in the pvSync.i file
> > > that is causing the problem. It's at line 84:
> > > if (i >= 1000 -1) {
> > > state done;
> > > When I replaced the above by
> > > %% if (i >= 1000 -1) {
> > > state done;
> > > and ran the command
> > > pvSync.c.tmp
> > > in the O.cygwin-x86_64 directory, it produced pvSync.c.tmp without
> > > error.
> > > Tim
> > > [mailto:[email protected]] On Behalf Of Johnson, Andrew
> > > N. Sent: Sunday, April 13, 2014 9:38 PM
> > > To: Benjamin Franksen
> > > Cc: [email protected]
> > > Hi Ben,
> > > The OSCLASS for the cygwin-x86_64 architecture is 'cygwin32' so that
> > > include path is actually correct. This is an accident of history, as
> > > is the OSCLASS 'WIN32' of the windows-x64 architectures; the OS APIs
> > > didn't change significantly when they went to 64-bit and we didn't
> > > want to duplicate code unnecessarily, so we still use the old names.
> > > Your "impossible" assertion condition might not be (whatever it is).
> > > - Andrew
> > > Sent from my iPad
> > > > On Apr 13, 2014, at 5:52 PM, "Benjamin Franksen"
> > > > <[email protected]> wrote:
> > > > Hi Tim
> > > > looking at the make output, I notice that your include path has -
> > > > I../../../include/os/cygwin32, even though you compile for
> > > > O.cygwin-x86_64. This looks inconsistent to me, and could perhaps
> > > > explain the assertion failure. I may be wrong, though, in which
> > > > case we'd have to look deeper into what's broken (I have never
> > > > compiled on this platform, only on 32 bit Windows native).
> > > > Cheers
> > > > Ben
> > > > Am Sonntag, 13. April 2014, 17:17:11 schrieb Graber, Tim:
> > > >> I am trying to build the EPICS Sequencer (version seq-2.1.15)
> > > >> using
> > > >> 64-bit Cygwin. I get the following error when I build the test
> > > >> directory and a similar error when building the examples
> > > >> directory. If I comment out the test and examples directories in
> > > >> the Makefile, the src directory builds fine. Any help will be
> > > >> appreciated. Thanks, Tim Graber
> > > >> gcc -c -D_POSIX_THREADS -D_POSIX_TIMERS -DUNIX
> > > >> -DCYGWIN32 -O3 -Wall -m64 -DEPICS_DLL_NO -MMD -I.
> > > >> -I../O.Common -I. -I.. -I../../../include/os/cygwin32
> > > >> -I../../../include
> > > >> -I/usr/local/EPICS/base/include/os/cygwin32
> > > >> -I/usr/local/EPICS/base/include>>
> > > >> opttVar.c g++ -o opttVar.exe -static
> > > >> -L/usr/local/epics/base-3.14.12.4/seq-2.1.15/lib/cygwin-x86_64
> > > >> -L/usr/local/EPICS/base-3.14.12.4/lib/cygwin-x86_64 -m64
> > > >> opttVar.o subThreadSleep.o
> > > >> seqSoftIoc_registerRecordDeviceDriver.o
> > > >> testSupport.o -lseq -lpv -lrecIoc -lsoftDevIoc -lmiscIoc
> > > >> -lrsrvIoc
> > > >> -ldbtoolsIoc -lasIoc -ldbIoc -lregistryIoc -ldbStaticIoc -lca
> > > >> -lCom
> > > >> -lpthread -lm preprocessing ../pvSync.st
> > > >> gcc -x c -E -D_POSIX_THREADS -D_POSIX_TIMERS -DUNIX
> > > >> -DCYGWIN32 -I. -I../O.Common -I. -I..
> > > >> -I../../../include -I/usr/local/EPICS/base/include/os/cygwin32
> > > >> -I/usr/local/EPICS/base/include ../pvSync.st > pvSync.i
> > > >> converting pvSync.i
> > > >> pvSync.c.tmp
> > > >> assertion "impossible" failed: file "../analysis.c", line 209,
> > > >> function: defn_list_from_scope
> > > >> ../../../configure/RULES_BUILD:62:
> > > >> recipe for target 'pvSync.c' failed make[3]: *** [pvSync.c]
> > > >> Aborted (core dumped)
> > > >> make[3]: Leaving directory
> > > >> '/usr/local/epics/base-3.14.12.4/seq-2.1.15/test/validate/O.cygwi
> > > >> n-
> > > >> x86_64' /usr/local/EPICS/base/configure/RULES_ARCHS:63: recipe
> > > >> for target 'install.cygwin-x86_64' failed make[2]: ***
> > > >> [install.cygwin-x86_64] Error 2
> > > >> make[2]: Leaving directory
> > > >> '/usr/local/epics/base-3.14.12.4/seq-2.1.15/test/validate'
> > > >> /usr/local/EPICS/base/configure/RULES_DIRS:70: recipe for target
> > > >> 'validate.install' failed make[1]: *** [validate.install] Error
> > > >> 2
> > > >> make[1]: Leaving directory
> > > >> '/usr/local/epics/base-3.14.12.4/seq-2.1.15/test'
> > > >> 'test.install' failed make: *** [test.install] Error 2
> > > >> Timothy Graber
> > > >> Research Professor
> > > >> Washington State University
> > > >> Manager, Dynamic Compression Sector c/o Argonne National
> > > >> Laboratory Bld. 438F/F002
> > > >> 9700 S. Cass Ave
> > > >> Argonne, IL 60439
> > > >> Phone: (630)252-0462
> > > > Perl: There Is More Than One Way To Do It
> > > > Python: There Is One Way To Do It
> > > > Haskell: There Is One Way To Do It, Up To Isomorphisµ
> > "Make it so they have to reboot after every typo." ― Scott Adams
signature.asc
Description: This is a digitally signed message part.
RE: Streamdevice 2.6 autoconnection failure using drvAsynSerialPort Mark Rivers
Re: Array Writes to HW Registers - How to ??? Stephen Beckwith
<2014>
Modbus R2-6 available Mark Rivers
<2014>
