1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: RE: Streamdevice 2.6 autoconnection failure using drvAsynSerialPort
To: Mark Rivers <[email protected]>, "[email protected]" <[email protected]>
Date: Fri, 11 Apr 2014 16:07:25 +0000
Hi
This might be too late after the last post from you, but I've tried, so I'm reporting:
1. Printf didn't show anything after physical re-connection. Execution of Asyn code didn't get there.
2. With SynApps 5.6, the PORT gets disconnected correctly.
asynReport(10, PORT)
PORT multiDevice:No canBlock:Yes autoConnect:Yes
    enabled:Yes connected:No numberConnects 1
    nDevices 0 nQueued 0 blocked:No
    asynManagerLock:No synchronousLock:No
    exceptionActive:No exceptionUsers 1 exceptionNotifys 0
    interposeInterfaceList
        asynOctet pinterface 0x7f00835be740 drvPvt 0x9f6480
    interfaceList
        asynCommon pinterface 0x7f00835bc060 drvPvt 0x9f3580
        asynOption pinterface 0x7f00835bc080 drvPvt 0x9f3580
        asynOctet pinterface 0x7f00835bdf80 drvPvt 0x9f3580
Serial line /dev/ttyUSBPIC: Disconnected
                    fd: -1
    Characters written: 112
       Characters read: 196
And the IOC shell reports:
2014/04/11 17:09:09.307 PORT EEE:volts: connection closed in write
2014/04/11 17:09:10.307 PORT EEE:volts: pasynCommon->connect() failed: /dev/ttyUSBPIC Can't open  No such device
2014/04/11 17:09:10.307 PORT EEE:volts: Protocol aborted
2014/04/11 17:09:11.307 PORT EEE:volts: pasynCommon->connect() failed: /dev/ttyUSBPIC Can't open  No such device
2014/04/11 17:09:11.307 PORT EEE:volts: Protocol aborted
2014/04/11 17:09:11.307 /dev/ttyUSBPIC Can't open  No such device PORT -1 autoConnect could not connect
3. With SynApps 5.6 IOC running on either Debian Linux (kernel 3.2.0) or Scientific Linux (kernel 2.6.32-431.11.2), everything is alright.
4. Persistent symbolic-link names seemed to me as not enough, since they die when target file (e.g.: ttyUSB0) disappears.
I went with persistent name of /dev/ device file:
KERNEL=="ttyUSB*", ATTRS{idVendor}=="067b", ATTRS{idProduct}=="2303", OPTIONS="ignore_remove", NAME+="ttyUSBPIC"
# (use of ATTRS{serial}=="FTFCFOX8" instead of Vendor/Device ID provides really unique identification, but it is not set in every usb device)
However minor (not major) device number can change with a fast physical re-connection, since udev/kernel frees attached devices slowly.
Tomas
Od: Mark Rivers [[email protected]]
Odesláno: 10. dubna 2014 14:22
Komu: Mazanec Tomáš; [email protected]
Předmět: RE: Streamdevice 2.6 autoconnection failure using drvAsynSerialPort
Hi Mazanec,
This is the code in drvAsynSerialPort that is being executed.  I have removed the vxWorks specific code for simplicity, since you are not using vxWorks:
    for (;;) {
        if (!timerStarted && (tty->readTimeout > 0)) {
            epicsTimerStartDelay(tty->timer, tty->readTimeout);
            timerStarted = 1;
        thisRead = read(tty->fd, data, maxchars);
        if (thisRead > 0) {
            asynPrintIO(pasynUser, ASYN_TRACEIO_DRIVER, data, thisRead,
                       "%s read %d\n", tty->serialDeviceName, thisRead);
            nRead = thisRead;
            tty->nRead += thisRead;
            break;
        else {
            if ((thisRead < 0) && (errno != EWOULDBLOCK)
                               && (errno != EINTR)
                               && (errno != EAGAIN)) {
                epicsSnprintf(pasynUser->errorMessage,pasynUser->errorMessageSize,
                                "%s read error: %s",
                                        tty->serialDeviceName, strerror(errno));
                closeConnection(pasynUser,tty);
                status = asynError;
                break;
            if (tty->readTimeout == 0)
                tty->timeoutFlag = 1;
        if (tty->timeoutFlag)
            break;
So the behavior depends on the return value from the system read() function.  If read returns a value < 0 then the value of errno is checked.  If it is not EWOULDBLOCK, EINTR, or EAGAIN then the serial port connection is closed.  At that point asyn should show the port as disconnected.  So here are my questions:
- Can you put in a printf to show the value of errno when the read() fails?
- On the older synApps 5.6 does asyn show that the port is disconnected when you remove the device?  If so, we need to figure out how it gets into the disconnected state, and why that does not happen in the new version.
- When you run on synApps 5.6 on the new version of Linux does it behave correctly, i.e. the device starts working again when you reconnect?  If so then we can probably rule out the possibility that a different value of errno is being set in the new version of Linux.
- Perhaps in StreamDevice 2.5.1 it was forcing the disconnect, and in 2.6 it is not?  Can you run 2.5.1 with asyn 4.21 and see what happens?
- Can you tell me what lines you put in udev to force the same serial port to be used whenever the device connects?  I have a USB serial device I can use for testing on Linux, so I should be able to reproduce the problem if you tell me how to do that.
Sent: Thursday, April 10, 2014 6:24 AM
To: Mark Rivers; [email protected]
In synApps 5.7, if the usb-serial device is physically disconnected, while the IOC is running, the command:
asynReport(10, PORT) says the asyn port is still connected:
    enabled:Yes connected:Yes numberConnects 1
    asynManagerLock:No synchronousLock:Yes
    exceptionActive:No exceptionUsers 2 exceptionNotifys 0
        asynOctet pinterface 0x7fbbfb51f6a0 drvPvt 0x1489670
    interfaceList
        asynCommon pinterface 0x7fbbfb51ca80 drvPvt 0x1486740
        asynOption pinterface 0x7fbbfb51caa0 drvPvt 0x1486740
        asynOctet pinterface 0x7fbbfb51ee40 drvPvt 0x1486740
Serial line /dev/ttyUSBPIC: Connected
                    fd: 5
    Characters written: 164
       Characters read: 287
What also happens, and I didn't noticed, is IOC's process takes 100% CPU usage and traceFlow bit within traceMask in Asyn reports hundreds of these lines in a second:
2014/04/10 13:06:39.575 /dev/ttyUSBPIC read.
However, an attempt to reconnect asyn port with asynRecord ends with no success and this messsage output:
2014/04/10 13:04:32.374 EEE:asynrec: special queueRequest timeout
Tomas
Odesláno: 8. dubna 2014 18:47
In synApps 5.7 what happens if you use an asynRecord to force the asynPort to reconnect.  Does StreamDevice then start working?
When the device is disconnected does asyn report that it is disconnected?  Use the following command when the device is disconnected:
asynReport 10 ASYN_PORT_NAME
Sent: Tuesday, April 08, 2014 9:20 AM
Hi Mark
Thanks for a quick response.
The IOC runs on Scientific Linux 6.5 x86-64 and its default kernel.  Yes, I have upgraded it (from 6.4 to 6.5) prior to SynApps upgrade.
Linux udev system is configured in a way that my usb-serial device gets always the same device name (/dev/ttyUSBPIC) no matter what other devices are present (major, minor device numbers can change).
I've double-checked Asyn 4.21 re-connection ability using asynRecord (.CNCT, .PCNCT).
It works fine, so the issue might be a glitch in the new StreamDevice.
Nevertheless, I've kept SynApps-5-6 installed and compared re-connection behavior to 5.7.
The older version is fine -- If my usb-serial device is physically disconnected, IOC with SynApps-5-6 reports:
2014/04/07 16:55:20.994 PORT EEE:volts: connection closed in write
2014/04/07 16:55:25.994 PORT EEE:volts: pasynCommon->connect() failed: /dev/ttyUSBPIC Can't open  No such device
2014/04/07 16:55:25.994 PORT EEE:volts: Protocol aborted
and when the usb-serial device is connected back, R/W operations continue as usual.
Whereas with the new version (5.7), IOC shell is kind of silent unless I try to reload StreamDevice protocol :
epics> streamReload EEE:volts
2014/04/08 11:46:52.567355 _main_ StreamCore::finishProtocol(EEE:volts): Still waiting for writeSuccess()
2014/04/08 11:46:52.567398 _main_ EEE:volts: Protocol aborted
or unless I try to use StreamDevice's connect command (through the EEE:CONNECT PV):
epics> dbpf EEE:CONNECT 1
DBR_STRING:          "ON"
epics> 2014/04/07 17:10:06.446437 timerQueue EEE:CONNECT: Connect failed
2014/04/07 17:10:06.446482 timerQueue EEE:CONNECT: Protocol aborted
?2014/04/07 17:10:07.536724 timerQueue EEE:CONNECT: Connect failed
?2014/04/07 17:10:07.536747 timerQueue EEE:CONNECT: Protocol aborted
but the connection is not re-established anyway. Furthermore, protocol reload makes IOC shell stuck.
There is an older post about different connection issue, but also with StreamDevice & Asyn.
So, with the new version (5.7), I've checked whether the timerQueue thread is OK and checked for any locked mutexes.
The thread is OK.
There is a mutex reported as locked once the usb-serial device is diconnected, however it remains locked when the device is connected back.
epics> epicsMutexShowAll 1
ellCount(&mutexList) 112 ellCount(&freeList) 0
epicsMutexId 0x1d5bfd0 source ../../asyn/asynDriver/asynManager.c line 1868
No mutexes remain locked after the usb-device re-connection with the older version (5.6). But this could be just a result of the issue.
Tomas
Odesláno: 7. dubna 2014 18:36
Komu: Mazanec Tomáš; [email protected]<mailto:[email protected]>
Hi Tomas,
There were no substantive changes in the drvAsynSerialPort code between asyn 4.18 and asyn 4.21.  SVN tag 1917 is asyn 4.18 and tag 2203 is asyn 4.21.
Here are the differences:
corvette:asyn/asyn/drvAsynSerial>svn diff -r1917:2203 drvAsynSerialPort*
Index: drvAsynSerialPort.c
--- drvAsynSerialPort.c (revision 1917)
+++ drvAsynSerialPort.c (revision 2203)
@@ -103,12 +103,12 @@
     if ((ioctl(tty->fd, FIOBAUDRATE, tty->baud) < 0)
      && (ioctl(tty->fd, SIO_BAUD_SET, tty->baud) < 0)) {
         epicsSnprintf(pasynUser->errorMessage, pasynUser->errorMessageSize,
-                                "SIO_BAUD_SET failed: %s\n", strerror(errno));
+                                "SIO_BAUD_SET failed: %s", strerror(errno));
         return asynError;
     if (ioctl(tty->fd, SIO_HW_OPTS_SET, tty->termios.c_cflag) < 0) {
-                               "SIO_HW_OPTS_SET failed: %s\n", strerror(errno));
+                               "SIO_HW_OPTS_SET failed: %s", strerror(errno));
         return asynError;
#else
@@ -116,7 +116,7 @@
     tty->termios.c_cflag |= CREAD;
     if (tcsetattr(tty->fd, TCSANOW, &tty->termios) < 0) {
-                                   "tcsetattr failed: %s\n", strerror(errno));
+                                   "tcsetattr failed: %s", strerror(errno));
         return asynError;
#endif
@@ -253,12 +253,12 @@
         if(cfsetispeed(&tty->termios,baudCode) < 0 ) {
-                "cfsetispeed returned %s\n",strerror(errno));
+                "cfsetispeed returned %s",strerror(errno));
             return asynError;
         if(cfsetospeed(&tty->termios,baudCode) < 0 ) {
-                "cfsetospeed returned %s\n",strerror(errno));
+                "cfsetospeed returned %s",strerror(errno));
             return asynError;
@@ -452,7 +452,7 @@
     tcflush(tty->fd, TCOFLUSH);
#endif
#ifdef vxWorks
-    ioctl(tty->fd, FIOCANCEL, NULL);
+    ioctl(tty->fd, FIOCANCEL, 0);
      * Since it is possible, though unlikely, that we got here before the
      * slow system call actually started, we arrange to poke the thread
@@ -509,14 +509,14 @@
     if ((tty->fd = open(tty->serialDeviceName, O_RDWR|O_NOCTTY|O_NONBLOCK, 0)) < 0) {
-                            "%s Can't open  %s\n",
+                            "%s Can't open  %s",
         return asynError;
#if defined(FD_CLOEXEC) && !defined(vxWorks)
     if (fcntl(tty->fd, F_SETFD, FD_CLOEXEC) < 0) {
-                            "Can't set %s close-on-exec flag: %s\n",
+                            "Can't set %s close-on-exec flag: %s",
         close(tty->fd);
         tty->fd = -1;
@@ -578,7 +578,7 @@
     asynPrint(pasynUser, ASYN_TRACE_FLOW,
                             "%s write.\n", tty->serialDeviceName);
     asynPrintIO(pasynUser, ASYN_TRACEIO_DRIVER, data, numchars,
-                            "%s write %d\n", tty->serialDeviceName, numchars);
+                            "%s write %lu\n", tty->serialDeviceName, (unsigned long)numchars);
     if (tty->fd < 0) {
                                 "%s disconnected:", tty->serialDeviceName);
@@ -672,7 +672,7 @@
     if (maxchars <= 0) {
-            "%s maxchars %d Why <=0?\n",tty->serialDeviceName,(int)maxchars);
+            "%s maxchars %d Why <=0?",tty->serialDeviceName,(int)maxchars);
         return asynError;
     if (tty->readTimeout != pasynUser->timeout) {
@@ -775,8 +775,8 @@
        data[nRead] = 0;
     else if (gotEom)
         *gotEom = ASYN_EOM_CNT;
-    asynPrint(pasynUser, ASYN_TRACE_FLOW, "%s read %d, return %d\n",
-                            tty->serialDeviceName, *nbytesTransfered, status);
+    asynPrint(pasynUser, ASYN_TRACE_FLOW, "%s read %lu, return %d\n",
+                            tty->serialDeviceName, (unsigned long)*nbytesTransfered, status);
     return status;
So the changes are removing “\n” from the end of epicsSNprintf formats, and some other minor changes to avoid compiler warnings.
Is this on Linux?
Have you upgraded the OS?
I think any change in behavior is likely due either to a change in StreamDevice or a change in the OS, and not due to any change in asyn.
From: [email protected]<mailto:[email protected]> [mailto:[email protected]] On Behalf Of Mazanec Tomáš
Sent: Monday, April 07, 2014 11:13 AM
To: [email protected]<mailto:[email protected]>
Subject: Streamdevice 2.6 autoconnection failure using drvAsynSerialPort
Hello
Automatic re-connection seems to be broken with recent streamdevice & asyn.
Recently, we upgraded SynApps from 5.6 to version 5.7 and so streamdevice 2.5.1 & Asyn 4.18 to streamdevice 2.6 & Asyn 4.21.
One of IOCs here is using serial port ( as /dev/ttyUSBxxx ) and device controlled by it disconnects often.
With SynApps 5.6, everything ran smoothly. After the upgrade to SynApps 5.7, the IOC is not able to reconnect anymore.
As far as I've tested, drvAsynIPPort reconnects well with both SynApps 5.6 and 5.7, so its just serial port variant which is affected.
Could you anyone address this issue and provide some hints or fix.
Tomas Mazanec
ELI Beamlines Czech Republic
http://www.eli-beams.eu
+420 26605 2566
+420 601 555 066
Address:
Institute of Physics, Academy of Sciences
Na Slovance 2
182 21 Prague
Czech Republic
*** DB template file:
record(ai, "$(NAME):volts")
    field(DTYP, "stream")
    field(INP, "@$(SCONF) get_volts $(ASYNPORT)")
    field(SCAN, "5 second")
    field(PINI, "YES")
    field(VAL, "0")
    field(PREC, "2")
    field(EGU, "V")
record(bo, "$(NAME):CONNECT") {
  field(OUT, "@$(SCONF) connect $(ASYNPORT)")
  field(PINI, "NO")
  field(HIGH, "0.1")
  field(ZNAM, "OFF")
  field(ONAM, "ON")
*** streamdev protocol file:
get_volts    {out "\x11\x3f\x76\x04"; in "\x76%f\x04\x00" }
connect {
    ExtraInput = Ignore;
    connect 1000;
*** EPICS IOC shell LOG file:
epicsEnvSet("SYSNAME","EEE")
# streamdevice protocol file-name
epicsEnvSet("SYSSCONF","proto.sdp")
# name of asyndriver port (arbitrary)
epicsEnvSet("SYSASYNPORT","PORT")
# For streamdevice
epicsEnvSet STREAM_PROTOCOL_PATH :protocols:./cfg
# Setup asyn driver
drvAsynSerialPortConfigure ("PORT","/dev/ttyUSBPIC", 0, 1, 0)
asynSetOption ("PORT", 0, "baud", "9600")
asynSetOption ("PORT", 0, "bits", "8")
asynSetOption ("PORT", 0, "parity", "none")
asynSetOption ("PORT", 0, "stop", "1")
asynReport(1, "PORT")
PORT multiDevice:No canBlock:Yes autoConnect:No
    enabled:Yes connected:No numberConnects 0
                    fd: -1
    Characters written: 0
       Characters read: 0
asynSetTraceIOMask("PORT",0,0x4)
asynSetTraceMask("PORT",0,0x9)
dbLoadRecords("aaa.template","NAME=EEE, SCONF=proto.sdp, ASYNPORT=PORT")
iocInit()
Starting iocInit
## EPICS R3.14.12.4 $Date: Mon 2013-12-16 15:51:45 -0600$
## EPICS Base built Mar 11 2014
2014/04/07 17:07:24.528 /dev/ttyUSBPIC write 4
11 3f 76 04
2014/04/07 17:07:24.542 /dev/ttyUSBPIC read 1
76
2014/04/07 17:07:24.543 /dev/ttyUSBPIC read 1
35
2014/04/07 17:07:24.544 /dev/ttyUSBPIC read 1
2e
2014/04/07 17:07:24.545 /dev/ttyUSBPIC read 1
31
2014/04/07 17:07:24.547 /dev/ttyUSBPIC read 1
39
2014/04/07 17:07:24.548 /dev/ttyUSBPIC read 1
04
2014/04/07 17:07:24.549 /dev/ttyUSBPIC read 1
00
2014/04/07 17:07:29.026 /dev/ttyUSBPIC write 4
11 3f 76 04
2014/04/07 17:07:29.039 /dev/ttyUSBPIC read 1
76
2014/04/07 17:07:29.041 /dev/ttyUSBPIC read 2
35 2e
2014/04/07 17:07:29.042 /dev/ttyUSBPIC read 1
31
2014/04/07 17:07:29.043 /dev/ttyUSBPIC read 1
39
2014/04/07 17:07:29.044 /dev/ttyUSBPIC read 1
04
2014/04/07 17:07:29.046 /dev/ttyUSBPIC read 1
00
epics>
epics>
epics>
epics> scanppl
Records with SCAN = '5 second' (0 over-runs):
    EEE:volts
epics> dbgf EEE:volts
DBR_DOUBLE:         5.19
epics>
epics> dbpr EEE:volts 111
ACKS: INVALID       ACKT: YES           ADEL: 0             ALST: 5.19
AOFF: 0             ASG:                ASLO: 1             ASP: (nil)
BKPT: 00            DESC:               DISA: 0             DISP: 0
DISS: NO_ALARM      DISV: 1             DPVT: 0x1911dd0     DSET: 0x7fa011b09a40
DTYP: stream        EGU: V              EGUF: 0             EGUL: 0
EOFF: 0             ESLO: 1             EVNT: 0             FLNK:CONSTANT 0
HHSV: NO_ALARM      HIGH: 0             HIHI: 0             HOPR: 0
HSV: NO_ALARM       HYST: 0             INIT: 0
INP:INST_IO @proto.sdp get_volts PORT   LALM: 5.19          LBRK: 0
LCNT: 11            LINR: NO CONVERSION LLSV: NO_ALARM      LOLO: 0
LOPR: 0             LOW: 0              LSET: 0x1917c90     LSV: NO_ALARM
MDEL: 0
MLIS: 30 69 02 b0 9f 7f 00 00 30 69 02 b0 9f 7f 00 00 01 00 00 00
MLOK: 40 76 90 01 00 00 00 00           MLST: 5.19          NAME: EEE:volts
NSEV: NO_ALARM      NSTA: NO_ALARM      ORAW: 0             PACT: 1
PBRK: (nil)         PHAS: 0             PINI: YES           PPN: (nil)
PPNR: (nil)         PREC: 2             PRIO: LOW           PROC: 0
PUTF: 0             RDES: 0x1885ff0     ROFF: 0             RPRO: 0
RSET: 0x7fa0118c7a80                    RVAL: 0             SCAN: 5 second
SDIS:CONSTANT       SEVR: INVALID       SIML:CONSTANT       SIMM: NO
SIMS: NO_ALARM      SIOL:CONSTANT       SMOO: 0             SPVT: 0x1913f00
STAT: SCAN          SVAL: 0             TIME: 2014-04-07 17:07:34.247219579
TPRO: 0             TSE: 0              TSEL:CONSTANT       UDF: 0
VAL: 5.19
epics>
epics> dbgf EEE:volts.SEVR
DBR_STRING:          "INVALID"
epics>
DBR_STRING:          "ON"
epics> ?[31;1m2014/04/07 17:10:06.446437 timerQueue EEE:CONNECT: Connect failed
?[0m?[31;1m2014/04/07 17:10:06.446482 timerQueue EEE:CONNECT: Protocol aborted
?[0m?[31;1m2014/04/07 17:10:07.536724 timerQueue EEE:CONNECT: Connect failed
?[0m?[31;1m2014/04/07 17:10:07.536747 timerQueue EEE:CONNECT: Protocol aborted
?[0m
epics>
epics> var streamDebug 1
2014/04/07 17:10:35.596373 _main_ StreamEpics.cc:711: Stream::process(EEE:CONNECT) start
2014/04/07 17:10:35.596411 _main_ StreamCore.cc:410: StreamCore::startProtocol(EEE:CONNECT, startMode=StartNormal)
2014/04/07 17:10:35.596426 _main_ StreamCore.cc:552: StreamCore::evalCommand(EEE:CONNECT): activeCommand = connect
2014/04/07 17:10:35.596436 _main_ AsynDriverInterface.cc:1347: AsynDriverInterface::connectRequest EEE:CONNECT
2014/04/07 17:10:35.596446 _main_ StreamEpics.cc:723: Stream::process(EEE:CONNECT): protocol started
DBR_STRING:          "ON"
epics> 2014/04/07 17:10:36.591508 timerQueue AsynDriverInterface.cc:1473: AsynDriverInterface::handleTimeout(EEE:CONNECT)
?[31;1m2014/04/07 17:10:36.591531 timerQueue EEE:CONNECT: Connect failed
?[0m2014/04/07 17:10:36.591539 timerQueue StreamCore.cc:517: StreamCore::finishProtocol(EEE:CONNECT, status=Fault) not bus owner
2014/04/07 17:10:36.591545 timerQueue AsynDriverInterface.cc:1416: AsynDriverInterface::finish(EEE:CONNECT) start
2014/04/07 17:10:36.591551 timerQueue AsynDriverInterface.cc:1426: AsynDriverInterface::finish(EEE:CONNECT) done
?[31;1m2014/04/07 17:10:36.591557 timerQueue EEE:CONNECT: Protocol aborted
?[0m2014/04/07 17:10:36.591589 cbLow StreamEpics.cc:896: streamRecordProcessCallback(EEE:CONNECT) processing record
2014/04/07 17:10:36.591622 cbLow StreamEpics.cc:691: Stream::process(EEE:CONNECT) error status=UDF (17)
2014/04/07 17:10:36.591646 cbLow StreamEpics.cc:901: streamRecordProcessCallback(EEE:CONNECT) processing record done
2014/04/07 17:10:36.686741 cbLow StreamEpics.cc:711: Stream::process(EEE:CONNECT) start
2014/04/07 17:10:36.686766 cbLow StreamCore.cc:410: StreamCore::startProtocol(EEE:CONNECT, startMode=StartNormal)
2014/04/07 17:10:36.686779 cbLow StreamCore.cc:552: StreamCore::evalCommand(EEE:CONNECT): activeCommand = connect
2014/04/07 17:10:36.686785 cbLow AsynDriverInterface.cc:1347: AsynDriverInterface::connectRequest EEE:CONNECT
2014/04/07 17:10:36.686796 cbLow StreamEpics.cc:723: Stream::process(EEE:CONNECT): protocol started
2014/04/07 17:10:37.681881 timerQueue AsynDriverInterface.cc:1473: AsynDriverInterface::handleTimeout(EEE:CONNECT)
?[31;1m2014/04/07 17:10:37.681901 timerQueue EEE:CONNECT: Connect failed
?[0m2014/04/07 17:10:37.681909 timerQueue StreamCore.cc:517: StreamCore::finishProtocol(EEE:CONNECT, status=Fault) not bus owner
2014/04/07 17:10:37.681916 timerQueue AsynDriverInterface.cc:1416: AsynDriverInterface::finish(EEE:CONNECT) start
2014/04/07 17:10:37.681922 timerQueue AsynDriverInterface.cc:1426: AsynDriverInterface::finish(EEE:CONNECT) done
?[31;1m2014/04/07 17:10:37.681927 timerQueue EEE:CONNECT: Protocol aborted
?[0m2014/04/07 17:10:37.681958 cbLow StreamEpics.cc:896: streamRecordProcessCallback(EEE:CONNECT) processing record
2014/04/07 17:10:37.681981 cbLow StreamEpics.cc:691: Stream::process(EEE:CONNECT) error status=UDF (17)
2014/04/07 17:10:37.681994 cbLow StreamEpics.cc:901: streamRecordProcessCallback(EEE:CONNECT) processing record done
epics>
epics>
epics>
Streamdevice 2.6 autoconnection failure using drvAsynSerialPort Mazanec Tomáš
RE: Streamdevice 2.6 autoconnection failure using drvAsynSerialPort Mark Rivers
RE: Streamdevice 2.6 autoconnection failure using drvAsynSerialPort Mazanec Tomáš
Prev: RE: Streamdevice 2.6 autoconnection failure using drvAsynSerialPort Mark Rivers
Next: RE: Streamdevice 2.6 autoconnection failure using drvAsynSerialPort Mazanec Tomáš
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Next: Re: Streamdevice 2.6 autoconnection failure using drvAsynSerialPort Dirk Zimoch
ANJ, 17 Dec 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
