1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: RE: Recommended practice for cvtRecord chain initialization
To: Benjamin Franksen <[email protected]>, EPICS mailing list <[email protected]>
Date: Thu, 10 Apr 2014 11:15:14 -0700
Ben,
I tried the inverted table method without any success.
My test setup is simple
1/ I use the identity transformation table
0 0
1 1
2/ I use 2 analog out records one as my input X to the cvt record, the other as the output
3/ I test the record chain with the method "1D TABLE"
everything works as expected
4/ I change the method to "1D TABLE INVERTED" and reboot the test IOC
Because of the identity table, I expected the same behavior.
But whenever my cvtRecord is processed, the output is set to 0.0.
Am I missing something?
Emmanuel
> From: [email protected]
> To: [email protected]
> Subject: Re: Recommended practice for cvtRecord chain initialization
> Date: Fri, 14 Mar 2014 14:05:45 +0100
> Hi Emmanuel
> On Thursday, March 13, 2014 15:58:44 Emmanuel Mayssat wrote:
> > I have a recordAO (let's say a phase in deg) that is converted through
> > a cvtRecord (~ breakpoint table) to a voltageAO. We could assume that
> > the voltage on the device doesn't change while the IOC is off and
> > autosave everything.
> > But... in this particular case, where the hardware 'remembers' its
> > voltage setting (EEPROM or hardware stays on while IOC is off), the
> > chain above should be executed in the opposite direction at iocInit.
> > A possible way is to have another cvt record with the same
> > "breakpoint" table but with "1D table reversed" method and PINI=1. Is
> > this the recommended way?
> I did not have this problem in practice yet, but yes, this is how I
> would do it. You might need some additional record logic that disables
> the readback and reverse-conversion after the first (PINI) processing.
> You might also want to disable processing in the forward direction
> during the readback (this might be necessary if setting a value to the
> device has other side effects that you want to avoid).
> Cheers
> Ben
> "Make it so they have to reboot after every typo." ― Scott Adams
Recommended practice for cvtRecord chain initialization Emmanuel Mayssat
Re: Recommended practice for cvtRecord chain initialization Benjamin Franksen
Prev: Modbus R2-6 available Mark Rivers
Next: Re: Streamdevice 2.6 autoconnection failure using drvAsynSerialPort Dirk Zimoch
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: Recommended practice for cvtRecord chain initialization Benjamin Franksen
Next: Prioritizing Channel Access per Record? Brian Bevins
ANJ, 17 Dec 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
