1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: RE: Streamdevice 2.6 autoconnection failure using drvAsynSerialPort
To: 'Mazanec Tomáš' <[email protected]>, "[email protected]" <[email protected]>
Date: Mon, 7 Apr 2014 16:36:26 +0000
Hi Tomas,
There were no substantive changes in the drvAsynSerialPort code between asyn 4.18 and asyn 4.21.  SVN tag 1917 is asyn 4.18 and tag 2203 is asyn 4.21.
Here are the differences:
corvette:asyn/asyn/drvAsynSerial>svn diff -r1917:2203 drvAsynSerialPort*
Index: drvAsynSerialPort.c
--- drvAsynSerialPort.c (revision 1917)
+++ drvAsynSerialPort.c (revision 2203)
@@ -103,12 +103,12 @@
     if ((ioctl(tty->fd, FIOBAUDRATE, tty->baud) < 0)
      && (ioctl(tty->fd, SIO_BAUD_SET, tty->baud) < 0)) {
         epicsSnprintf(pasynUser->errorMessage, pasynUser->errorMessageSize,
-                                "SIO_BAUD_SET failed: %s\n", strerror(errno));
+                                "SIO_BAUD_SET failed: %s", strerror(errno));
         return asynError;
     if (ioctl(tty->fd, SIO_HW_OPTS_SET, tty->termios.c_cflag) < 0) {
-                               "SIO_HW_OPTS_SET failed: %s\n", strerror(errno));
+                               "SIO_HW_OPTS_SET failed: %s", strerror(errno));
         return asynError;
#else
@@ -116,7 +116,7 @@
     tty->termios.c_cflag |= CREAD;
     if (tcsetattr(tty->fd, TCSANOW, &tty->termios) < 0) {
-                                   "tcsetattr failed: %s\n", strerror(errno));
+                                   "tcsetattr failed: %s", strerror(errno));
         return asynError;
#endif
@@ -253,12 +253,12 @@
         if(cfsetispeed(&tty->termios,baudCode) < 0 ) {
             epicsSnprintf(pasynUser->errorMessage,pasynUser->errorMessageSize,
-                "cfsetispeed returned %s\n",strerror(errno));
+                "cfsetispeed returned %s",strerror(errno));
             return asynError;
         if(cfsetospeed(&tty->termios,baudCode) < 0 ) {
-                "cfsetospeed returned %s\n",strerror(errno));
+                "cfsetospeed returned %s",strerror(errno));
             return asynError;
@@ -452,7 +452,7 @@
     tcflush(tty->fd, TCOFLUSH);
#endif
#ifdef vxWorks
-    ioctl(tty->fd, FIOCANCEL, NULL);
+    ioctl(tty->fd, FIOCANCEL, 0);
      * Since it is possible, though unlikely, that we got here before the
      * slow system call actually started, we arrange to poke the thread
@@ -509,14 +509,14 @@
     if ((tty->fd = open(tty->serialDeviceName, O_RDWR|O_NOCTTY|O_NONBLOCK, 0)) < 0) {
-                            "%s Can't open  %s\n",
+                            "%s Can't open  %s",
                                     tty->serialDeviceName, strerror(errno));
         return asynError;
#if defined(FD_CLOEXEC) && !defined(vxWorks)
     if (fcntl(tty->fd, F_SETFD, FD_CLOEXEC) < 0) {
-                            "Can't set %s close-on-exec flag: %s\n",
+                            "Can't set %s close-on-exec flag: %s",
         close(tty->fd);
         tty->fd = -1;
@@ -578,7 +578,7 @@
     asynPrint(pasynUser, ASYN_TRACE_FLOW,
                             "%s write.\n", tty->serialDeviceName);
     asynPrintIO(pasynUser, ASYN_TRACEIO_DRIVER, data, numchars,
-                            "%s write %d\n", tty->serialDeviceName, numchars);
+                            "%s write %lu\n", tty->serialDeviceName, (unsigned long)numchars);
     if (tty->fd < 0) {
                                 "%s disconnected:", tty->serialDeviceName);
@@ -672,7 +672,7 @@
     if (maxchars <= 0) {
-            "%s maxchars %d Why <=0?\n",tty->serialDeviceName,(int)maxchars);
+            "%s maxchars %d Why <=0?",tty->serialDeviceName,(int)maxchars);
         return asynError;
     if (tty->readTimeout != pasynUser->timeout) {
@@ -775,8 +775,8 @@
        data[nRead] = 0;
     else if (gotEom)
         *gotEom = ASYN_EOM_CNT;
-    asynPrint(pasynUser, ASYN_TRACE_FLOW, "%s read %d, return %d\n",
-                            tty->serialDeviceName, *nbytesTransfered, status);
+    asynPrint(pasynUser, ASYN_TRACE_FLOW, "%s read %lu, return %d\n",
+                            tty->serialDeviceName, (unsigned long)*nbytesTransfered, status);
     return status;
So the changes are removing “\n” from the end of epicsSNprintf formats, and some other minor changes to avoid compiler warnings.
Is this on Linux?
Have you upgraded the OS?
I think any change in behavior is likely due either to a change in StreamDevice or a change in the OS, and not due to any change in asyn.
From: [email protected] [mailto:[email protected]] On Behalf Of Mazanec Tomáš
Sent: Monday, April 07, 2014 11:13 AM
To: [email protected]
Subject: Streamdevice 2.6 autoconnection failure using drvAsynSerialPort
Hello
Automatic re-connection seems to be broken with recent streamdevice & asyn.
Recently, we upgraded SynApps from 5.6 to version 5.7 and so streamdevice 2.5.1 & Asyn 4.18 to streamdevice 2.6 & Asyn 4.21.
One of IOCs here is using serial port ( as /dev/ttyUSBxxx ) and device controlled by it disconnects often.
With SynApps 5.6, everything ran smoothly. After the upgrade to SynApps 5.7, the IOC is not able to reconnect anymore.
As far as I've tested, drvAsynIPPort reconnects well with both SynApps 5.6 and 5.7, so its just serial port variant which is affected.
Could you anyone address this issue and provide some hints or fix.
Tomas Mazanec
ELI Beamlines Czech Republic
http://www.eli-beams.eu
+420 26605 2566
+420 601 555 066
Address:
Institute of Physics, Academy of Sciences
Na Slovance 2
182 21 Prague
Czech Republic
*** DB template file:
record(ai, "$(NAME):volts")
    field(DTYP, "stream")
    field(INP, "@$(SCONF) get_volts $(ASYNPORT)")
    field(SCAN, "5 second")
    field(PINI, "YES")
    field(VAL, "0")
    field(PREC, "2")
    field(EGU, "V")
record(bo, "$(NAME):CONNECT") {
  field(OUT, "@$(SCONF) connect $(ASYNPORT)")
  field(PINI, "NO")
  field(HIGH, "0.1")
  field(ZNAM, "OFF")
  field(ONAM, "ON")
*** streamdev protocol file:
get_volts    {out "\x11\x3f\x76\x04"; in "\x76%f\x04\x00" }
connect {
    ExtraInput = Ignore;
    connect 1000;
*** EPICS IOC shell LOG file:
epicsEnvSet("SYSNAME","EEE")
# streamdevice protocol file-name
epicsEnvSet("SYSSCONF","proto.sdp")
# name of asyndriver port (arbitrary)
epicsEnvSet("SYSASYNPORT","PORT")
# For streamdevice
epicsEnvSet STREAM_PROTOCOL_PATH :protocols:./cfg
# Setup asyn driver
drvAsynSerialPortConfigure ("PORT","/dev/ttyUSBPIC", 0, 1, 0)
asynSetOption ("PORT", 0, "baud", "9600")
asynSetOption ("PORT", 0, "bits", "8")
asynSetOption ("PORT", 0, "parity", "none")
asynSetOption ("PORT", 0, "stop", "1")
asynReport(1, "PORT")
PORT multiDevice:No canBlock:Yes autoConnect:No
    enabled:Yes connected:No numberConnects 0
    nDevices 0 nQueued 0 blocked:No
    asynManagerLock:No synchronousLock:No
    exceptionActive:No exceptionUsers 1 exceptionNotifys 0
Serial line /dev/ttyUSBPIC: Disconnected
                    fd: -1
    Characters written: 0
       Characters read: 0
asynSetTraceIOMask("PORT",0,0x4)
asynSetTraceMask("PORT",0,0x9)
dbLoadRecords("aaa.template","NAME=EEE, SCONF=proto.sdp, ASYNPORT=PORT")
iocInit()
Starting iocInit
## EPICS R3.14.12.4 $Date: Mon 2013-12-16 15:51:45 -0600$
## EPICS Base built Mar 11 2014
2014/04/07 17:07:24.528 /dev/ttyUSBPIC write 4
11 3f 76 04
2014/04/07 17:07:24.542 /dev/ttyUSBPIC read 1
76
2014/04/07 17:07:24.543 /dev/ttyUSBPIC read 1
35
2014/04/07 17:07:24.544 /dev/ttyUSBPIC read 1
2e
2014/04/07 17:07:24.545 /dev/ttyUSBPIC read 1
31
2014/04/07 17:07:24.547 /dev/ttyUSBPIC read 1
39
2014/04/07 17:07:24.548 /dev/ttyUSBPIC read 1
04
2014/04/07 17:07:24.549 /dev/ttyUSBPIC read 1
00
2014/04/07 17:07:29.026 /dev/ttyUSBPIC write 4
11 3f 76 04
2014/04/07 17:07:29.039 /dev/ttyUSBPIC read 1
76
2014/04/07 17:07:29.041 /dev/ttyUSBPIC read 2
35 2e
2014/04/07 17:07:29.042 /dev/ttyUSBPIC read 1
31
2014/04/07 17:07:29.043 /dev/ttyUSBPIC read 1
39
2014/04/07 17:07:29.044 /dev/ttyUSBPIC read 1
04
2014/04/07 17:07:29.046 /dev/ttyUSBPIC read 1
00
epics>
epics>
epics>
epics> scanppl
Records with SCAN = '5 second' (0 over-runs):
    EEE:volts
epics> dbgf EEE:volts
DBR_DOUBLE:         5.19
epics>
epics> dbpr EEE:volts 111
ACKS: INVALID       ACKT: YES           ADEL: 0             ALST: 5.19
AOFF: 0             ASG:                ASLO: 1             ASP: (nil)
BKPT: 00            DESC:               DISA: 0             DISP: 0
DISS: NO_ALARM      DISV: 1             DPVT: 0x1911dd0     DSET: 0x7fa011b09a40
DTYP: stream        EGU: V              EGUF: 0             EGUL: 0
EOFF: 0             ESLO: 1             EVNT: 0             FLNK:CONSTANT 0
HHSV: NO_ALARM      HIGH: 0             HIHI: 0             HOPR: 0
HSV: NO_ALARM       HYST: 0             INIT: 0
INP:INST_IO @proto.sdp get_volts PORT   LALM: 5.19          LBRK: 0
LCNT: 11            LINR: NO CONVERSION LLSV: NO_ALARM      LOLO: 0
LOPR: 0             LOW: 0              LSET: 0x1917c90     LSV: NO_ALARM
MDEL: 0
MLIS: 30 69 02 b0 9f 7f 00 00 30 69 02 b0 9f 7f 00 00 01 00 00 00
MLOK: 40 76 90 01 00 00 00 00           MLST: 5.19          NAME: EEE:volts
NSEV: NO_ALARM      NSTA: NO_ALARM      ORAW: 0             PACT: 1
PBRK: (nil)         PHAS: 0             PINI: YES           PPN: (nil)
PPNR: (nil)         PREC: 2             PRIO: LOW           PROC: 0
PUTF: 0             RDES: 0x1885ff0     ROFF: 0             RPRO: 0
RSET: 0x7fa0118c7a80                    RVAL: 0             SCAN: 5 second
SDIS:CONSTANT       SEVR: INVALID       SIML:CONSTANT       SIMM: NO
SIMS: NO_ALARM      SIOL:CONSTANT       SMOO: 0             SPVT: 0x1913f00
STAT: SCAN          SVAL: 0             TIME: 2014-04-07 17:07:34.247219579
TPRO: 0             TSE: 0              TSEL:CONSTANT       UDF: 0
VAL: 5.19
epics>
epics> dbgf EEE:volts.SEVR
DBR_STRING:          "INVALID"
epics>
epics> dbpf EEE:CONNECT 1
DBR_STRING:          "ON"
epics> ?[31;1m2014/04/07 17:10:06.446437 timerQueue EEE:CONNECT: Connect failed
?[0m?[31;1m2014/04/07 17:10:06.446482 timerQueue EEE:CONNECT: Protocol aborted
?[0m?[31;1m2014/04/07 17:10:07.536724 timerQueue EEE:CONNECT: Connect failed
?[0m?[31;1m2014/04/07 17:10:07.536747 timerQueue EEE:CONNECT: Protocol aborted
?[0m
epics>
epics> var streamDebug 1
2014/04/07 17:10:35.596373 _main_ StreamEpics.cc:711: Stream::process(EEE:CONNECT) start
2014/04/07 17:10:35.596411 _main_ StreamCore.cc:410: StreamCore::startProtocol(EEE:CONNECT, startMode=StartNormal)
2014/04/07 17:10:35.596426 _main_ StreamCore.cc:552: StreamCore::evalCommand(EEE:CONNECT): activeCommand = connect
2014/04/07 17:10:35.596436 _main_ AsynDriverInterface.cc:1347: AsynDriverInterface::connectRequest EEE:CONNECT
2014/04/07 17:10:35.596446 _main_ StreamEpics.cc:723: Stream::process(EEE:CONNECT): protocol started
DBR_STRING:          "ON"
epics> 2014/04/07 17:10:36.591508 timerQueue AsynDriverInterface.cc:1473: AsynDriverInterface::handleTimeout(EEE:CONNECT)
?[31;1m2014/04/07 17:10:36.591531 timerQueue EEE:CONNECT: Connect failed
?[0m2014/04/07 17:10:36.591539 timerQueue StreamCore.cc:517: StreamCore::finishProtocol(EEE:CONNECT, status=Fault) not bus owner
2014/04/07 17:10:36.591545 timerQueue AsynDriverInterface.cc:1416: AsynDriverInterface::finish(EEE:CONNECT) start
2014/04/07 17:10:36.591551 timerQueue AsynDriverInterface.cc:1426: AsynDriverInterface::finish(EEE:CONNECT) done
?[31;1m2014/04/07 17:10:36.591557 timerQueue EEE:CONNECT: Protocol aborted
?[0m2014/04/07 17:10:36.591589 cbLow StreamEpics.cc:896: streamRecordProcessCallback(EEE:CONNECT) processing record
2014/04/07 17:10:36.591622 cbLow StreamEpics.cc:691: Stream::process(EEE:CONNECT) error status=UDF (17)
2014/04/07 17:10:36.591646 cbLow StreamEpics.cc:901: streamRecordProcessCallback(EEE:CONNECT) processing record done
2014/04/07 17:10:36.686741 cbLow StreamEpics.cc:711: Stream::process(EEE:CONNECT) start
2014/04/07 17:10:36.686766 cbLow StreamCore.cc:410: StreamCore::startProtocol(EEE:CONNECT, startMode=StartNormal)
2014/04/07 17:10:36.686779 cbLow StreamCore.cc:552: StreamCore::evalCommand(EEE:CONNECT): activeCommand = connect
2014/04/07 17:10:36.686785 cbLow AsynDriverInterface.cc:1347: AsynDriverInterface::connectRequest EEE:CONNECT
2014/04/07 17:10:36.686796 cbLow StreamEpics.cc:723: Stream::process(EEE:CONNECT): protocol started
2014/04/07 17:10:37.681881 timerQueue AsynDriverInterface.cc:1473: AsynDriverInterface::handleTimeout(EEE:CONNECT)
?[31;1m2014/04/07 17:10:37.681901 timerQueue EEE:CONNECT: Connect failed
?[0m2014/04/07 17:10:37.681909 timerQueue StreamCore.cc:517: StreamCore::finishProtocol(EEE:CONNECT, status=Fault) not bus owner
2014/04/07 17:10:37.681916 timerQueue AsynDriverInterface.cc:1416: AsynDriverInterface::finish(EEE:CONNECT) start
2014/04/07 17:10:37.681922 timerQueue AsynDriverInterface.cc:1426: AsynDriverInterface::finish(EEE:CONNECT) done
?[31;1m2014/04/07 17:10:37.681927 timerQueue EEE:CONNECT: Protocol aborted
?[0m2014/04/07 17:10:37.681958 cbLow StreamEpics.cc:896: streamRecordProcessCallback(EEE:CONNECT) processing record
2014/04/07 17:10:37.681981 cbLow StreamEpics.cc:691: Stream::process(EEE:CONNECT) error status=UDF (17)
2014/04/07 17:10:37.681994 cbLow StreamEpics.cc:901: streamRecordProcessCallback(EEE:CONNECT) processing record done
epics>
epics>
epics>
RE: Streamdevice 2.6 autoconnection failure using drvAsynSerialPort Mazanec Tomáš
Prev: reminder for visa application of EPICS meeting 2014 Yuan He
Next: RE: SYNC not updating VAL - motor Mooney, Tim M.
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Streamdevice 2.6 autoconnection failure using drvAsynSerialPort Mazanec Tomáš
Next: RE: Streamdevice 2.6 autoconnection failure using drvAsynSerialPort Mazanec Tomáš
ANJ, 17 Dec 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
