Hello
Automatic re-connection seems to be broken with recent streamdevice & asyn.
Recently, we upgraded SynApps from 5.6 to version 5.7 and so streamdevice 2.5.1 & Asyn 4.18 to streamdevice 2.6 & Asyn 4.21.
One of IOCs here is using serial port ( as /dev/ttyUSBxxx ) and device controlled by it disconnects often.
With SynApps 5.6, everything ran smoothly. After the upgrade to SynApps 5.7, the IOC is not able to reconnect anymore.
As far as I've tested, drvAsynIPPort reconnects well with both SynApps 5.6 and 5.7, so its just serial port variant which is affected.
Could you anyone address this issue and provide some hints or fix.
Tomas Mazanec
ELI Beamlines Czech Republic
http://www.eli-beams.eu
+420 26605 2566
+420 601 555 066
Address:
Institute of Physics, Academy of Sciences
Na Slovance 2
182 21 Prague
Czech Republic
*** DB template file:
record(ai, "$(NAME):volts")
field(DTYP, "stream")
field(INP, "@$(SCONF) get_volts $(ASYNPORT)")
field(SCAN, "5 second")
field(PINI, "YES")
field(VAL, "0")
field(PREC, "2")
field(EGU, "V")
record(bo, "$(NAME):CONNECT") {
field(OUT, "@$(SCONF) connect $(ASYNPORT)")
field(PINI, "NO")
field(HIGH, "0.1")
field(ZNAM, "OFF")
field(ONAM, "ON")
*** streamdev protocol file:
get_volts {out "\x11\x3f\x76\x04"; in "\x76%f\x04\x00" }
connect {
ExtraInput = Ignore;
connect 1000;
*** EPICS IOC shell LOG file:
epicsEnvSet("SYSNAME","EEE")
# streamdevice protocol file-name
epicsEnvSet("SYSSCONF","proto.sdp")
# name of asyndriver port (arbitrary)
epicsEnvSet("SYSASYNPORT","PORT")
# For streamdevice
epicsEnvSet STREAM_PROTOCOL_PATH :protocols:./cfg
# Setup asyn driver
drvAsynSerialPortConfigure ("PORT","/dev/ttyUSBPIC", 0, 1, 0)
asynSetOption ("PORT", 0, "baud", "9600")
asynSetOption ("PORT", 0, "bits", "8")
asynSetOption ("PORT", 0, "parity", "none")
asynSetOption ("PORT", 0, "stop", "1")
asynReport(1, "PORT")
PORT multiDevice:No canBlock:Yes autoConnect:No
enabled:Yes connected:No numberConnects 0
nDevices 0 nQueued 0 blocked:No
asynManagerLock:No synchronousLock:No
exceptionActive:No exceptionUsers 1 exceptionNotifys 0
Serial line /dev/ttyUSBPIC: Disconnected
fd: -1
Characters written: 0
Characters read: 0
asynSetTraceIOMask("PORT",0,0x4)
asynSetTraceMask("PORT",0,0x9)
dbLoadRecords("aaa.template","NAME=EEE, SCONF=proto.sdp, ASYNPORT=PORT")
iocInit()
Starting iocInit
## EPICS R3.14.12.4 $Date: Mon 2013-12-16 15:51:45 -0600$
## EPICS Base built Mar 11 2014
2014/04/07 17:07:24.528 /dev/ttyUSBPIC write 4
11 3f 76 04
2014/04/07 17:07:24.542 /dev/ttyUSBPIC read 1
76
2014/04/07 17:07:24.543 /dev/ttyUSBPIC read 1
35
2014/04/07 17:07:24.544 /dev/ttyUSBPIC read 1
2e
2014/04/07 17:07:24.545 /dev/ttyUSBPIC read 1
31
2014/04/07 17:07:24.547 /dev/ttyUSBPIC read 1
39
2014/04/07 17:07:24.548 /dev/ttyUSBPIC read 1
04
2014/04/07 17:07:24.549 /dev/ttyUSBPIC read 1
00
2014/04/07 17:07:29.026 /dev/ttyUSBPIC write 4
11 3f 76 04
2014/04/07 17:07:29.039 /dev/ttyUSBPIC read 1
76
2014/04/07 17:07:29.041 /dev/ttyUSBPIC read 2
35 2e
2014/04/07 17:07:29.042 /dev/ttyUSBPIC read 1
31
2014/04/07 17:07:29.043 /dev/ttyUSBPIC read 1
39
2014/04/07 17:07:29.044 /dev/ttyUSBPIC read 1
04
2014/04/07 17:07:29.046 /dev/ttyUSBPIC read 1
00
epics>
epics>
epics>
epics> scanppl
Records with SCAN = '5 second' (0 over-runs):
EEE:volts
epics> dbgf EEE:volts
DBR_DOUBLE: 5.19
epics>
epics> dbpr EEE:volts 111
ACKS: INVALID ACKT: YES ADEL: 0 ALST: 5.19
AOFF: 0 ASG: ASLO: 1 ASP: (nil)
BKPT: 00 DESC: DISA: 0 DISP: 0
DISS: NO_ALARM DISV: 1 DPVT: 0x1911dd0 DSET: 0x7fa011b09a40
DTYP: stream EGU: V EGUF: 0 EGUL: 0
EOFF: 0 ESLO: 1 EVNT: 0 FLNK:CONSTANT 0
HHSV: NO_ALARM HIGH: 0 HIHI: 0 HOPR: 0
HSV: NO_ALARM HYST: 0 INIT: 0
INP:INST_IO @proto.sdp get_volts PORT LALM: 5.19 LBRK: 0
LCNT: 11 LINR: NO CONVERSION LLSV: NO_ALARM LOLO: 0
LOPR: 0 LOW: 0 LSET: 0x1917c90 LSV: NO_ALARM
MDEL: 0
MLIS: 30 69 02 b0 9f 7f 00 00 30 69 02 b0 9f 7f 00 00 01 00 00 00
MLOK: 40 76 90 01 00 00 00 00 MLST: 5.19 NAME: EEE:volts
NSEV: NO_ALARM NSTA: NO_ALARM ORAW: 0 PACT: 1
PBRK: (nil) PHAS: 0 PINI: YES PPN: (nil)
PPNR: (nil) PREC: 2 PRIO: LOW PROC: 0
PUTF: 0 RDES: 0x1885ff0 ROFF: 0 RPRO: 0
RSET: 0x7fa0118c7a80 RVAL: 0 SCAN: 5 second
SDIS:CONSTANT SEVR: INVALID SIML:CONSTANT SIMM: NO
SIMS: NO_ALARM SIOL:CONSTANT SMOO: 0 SPVT: 0x1913f00
STAT: SCAN SVAL: 0 TIME: 2014-04-07 17:07:34.247219579
TPRO: 0 TSE: 0 TSEL:CONSTANT UDF: 0
VAL: 5.19
epics>
epics> dbgf EEE:volts.SEVR
DBR_STRING: "INVALID"
epics>
epics> dbpf EEE:CONNECT 1
DBR_STRING: "ON"
epics> ?[31;1m2014/04/07 17:10:06.446437 timerQueue EEE:CONNECT: Connect failed
?[0m?[31;1m2014/04/07 17:10:06.446482 timerQueue EEE:CONNECT: Protocol aborted
?[0m?[31;1m2014/04/07 17:10:07.536724 timerQueue EEE:CONNECT: Connect failed
?[0m?[31;1m2014/04/07 17:10:07.536747 timerQueue EEE:CONNECT: Protocol aborted
?[0m
epics>
epics> var streamDebug 1
2014/04/07 17:10:35.596373 _main_ StreamEpics.cc:711: Stream::process(EEE:CONNECT) start
2014/04/07 17:10:35.596411 _main_ StreamCore.cc:410: StreamCore::startProtocol(EEE:CONNECT, startMode=StartNormal)
2014/04/07 17:10:35.596426 _main_ StreamCore.cc:552: StreamCore::evalCommand(EEE:CONNECT): activeCommand = connect
2014/04/07 17:10:35.596436 _main_ AsynDriverInterface.cc:1347: AsynDriverInterface::connectRequest EEE:CONNECT
2014/04/07 17:10:35.596446 _main_ StreamEpics.cc:723: Stream::process(EEE:CONNECT): protocol started
DBR_STRING: "ON"
epics> 2014/04/07 17:10:36.591508 timerQueue AsynDriverInterface.cc:1473: AsynDriverInterface::handleTimeout(EEE:CONNECT)
?[31;1m2014/04/07 17:10:36.591531 timerQueue EEE:CONNECT: Connect failed
?[0m2014/04/07 17:10:36.591539 timerQueue StreamCore.cc:517: StreamCore::finishProtocol(EEE:CONNECT, status=Fault) not bus owner
2014/04/07 17:10:36.591545 timerQueue AsynDriverInterface.cc:1416: AsynDriverInterface::finish(EEE:CONNECT) start
2014/04/07 17:10:36.591551 timerQueue AsynDriverInterface.cc:1426: AsynDriverInterface::finish(EEE:CONNECT) done
?[31;1m2014/04/07 17:10:36.591557 timerQueue EEE:CONNECT: Protocol aborted
?[0m2014/04/07 17:10:36.591589 cbLow StreamEpics.cc:896: streamRecordProcessCallback(EEE:CONNECT) processing record
2014/04/07 17:10:36.591622 cbLow StreamEpics.cc:691: Stream::process(EEE:CONNECT) error status=UDF (17)
2014/04/07 17:10:36.591646 cbLow StreamEpics.cc:901: streamRecordProcessCallback(EEE:CONNECT) processing record done
2014/04/07 17:10:36.686741 cbLow StreamEpics.cc:711: Stream::process(EEE:CONNECT) start
2014/04/07 17:10:36.686766 cbLow StreamCore.cc:410: StreamCore::startProtocol(EEE:CONNECT, startMode=StartNormal)
2014/04/07 17:10:36.686779 cbLow StreamCore.cc:552: StreamCore::evalCommand(EEE:CONNECT): activeCommand = connect
2014/04/07 17:10:36.686785 cbLow AsynDriverInterface.cc:1347: AsynDriverInterface::connectRequest EEE:CONNECT
2014/04/07 17:10:36.686796 cbLow StreamEpics.cc:723: Stream::process(EEE:CONNECT): protocol started
2014/04/07 17:10:37.681881 timerQueue AsynDriverInterface.cc:1473: AsynDriverInterface::handleTimeout(EEE:CONNECT)
?[31;1m2014/04/07 17:10:37.681901 timerQueue EEE:CONNECT: Connect failed
?[0m2014/04/07 17:10:37.681909 timerQueue StreamCore.cc:517: StreamCore::finishProtocol(EEE:CONNECT, status=Fault) not bus owner
2014/04/07 17:10:37.681916 timerQueue AsynDriverInterface.cc:1416: AsynDriverInterface::finish(EEE:CONNECT) start
2014/04/07 17:10:37.681922 timerQueue AsynDriverInterface.cc:1426: AsynDriverInterface::finish(EEE:CONNECT) done
?[31;1m2014/04/07 17:10:37.681927 timerQueue EEE:CONNECT: Protocol aborted
?[0m2014/04/07 17:10:37.681958 cbLow StreamEpics.cc:896: streamRecordProcessCallback(EEE:CONNECT) processing record
2014/04/07 17:10:37.681981 cbLow StreamEpics.cc:691: Stream::process(EEE:CONNECT) error status=UDF (17)
2014/04/07 17:10:37.681994 cbLow StreamEpics.cc:901: streamRecordProcessCallback(EEE:CONNECT) processing record done
epics>
epics>
epics>
