1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: CSS : Multiple IOC pv(s) disconnect on ethernet unplug
To: EPICS Tech-Talk <[email protected]>
Date: Sat, 05 Apr 2014 15:31:12 +0200
On 04.04.2014 19:57, Kasemir, Kay wrote:
Hi:
I believe this is related to the general multiple-IOCs-on-same-computer problem, https://wiki-ext.aps.anl.gov/epics/index.php/How_to_Configure_Channel_Access
With
  EPICS_CA_ADDR_LIST = IP-of-that-server
you only get the IOC that was started last.
Same with
  EPICS_CA_ADDR_LIST = 127.0.0.1
You get the local IOC that was started last on the local computer.
You must use
  EPICS_CA_ADDR_LIST = broadcast-address-that-includes-that-server
to get all IOCs that are running on a computer.
With
  EPICS_CA_ADDR_LIST = "127.0.0.1 broadcast-address-that-includes-myself"
you get all IOCs on the local computer, but it's likely going 'over the network', even for the local IOC, since it would only find one of them via 127.0.0.1.
Use the *broadcast address* of the loopback interface (127.255.255.255) to get all local IOCs through that interface. 127.0.0.1 is the *unicast* IP of localhost, so the restrictions of unicast addresses in EPICS_CA_ADDR_LIST apply. (Also see https://wiki-ext.aps.anl.gov/epics/index.php/How_to_Make_Channel_Access_Reach_Multiple_Soft_IOCs_on_a_Linux_Host)
~Ralph
CSS : Multiple IOC pv(s) disconnect on ethernet unplug Sud Roy
Re: CSS : Multiple IOC pv(s) disconnect on ethernet unplug Kasemir, Kay
Prev: areaDetector R2-0 released Mark Rivers
Next: PCaPAC Abstract Deadline Extended Sebastian Marsching
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: CSS : Multiple IOC pv(s) disconnect on ethernet unplug Kasemir, Kay
Next: areaDetector R2-0 released Mark Rivers
ANJ, 17 Dec 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
