1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: build question
To: Andrew Johnson <[email protected]>, [email protected]
Date: Tue, 01 Apr 2014 16:08:27 -0400
Hi Andrew,
OK, I did that and it helped. I also needed to do the Makefile changes to make it RTEMS-specific as you suggested earlier and finally it built. THanks for your patience.
Pete.
On 04/01/2014 02:11 PM, Andrew Johnson wrote:
On 04/01/2014 12:33 PM, D Peter Siddons wrote:
peter@peter-Latitude-E4200:~/IOCs/det_640$ make
make -C ./configure install
make[1]: Entering directory `/home/peter/IOCs/det_640/configure'
perl /usr/local/epics/base/bin/linux-x86_64/makeMakefile.pl
O.RTEMS-uC5272 ../..
mkdir O.Common
make[1]: *** No rule to make target `install.linux-x86_64', needed by
`install.RTEMS-uC5272'.  Stop.
make[1]: Leaving directory `/home/peter/IOCs/det_640/configure'
make: *** [configure.install] Error 2
Ok, so the failure occurs when building in your configure directory; are
there any differences between the files you have in there and the ones
in the standard makeBaseApp template? You might want to try completely
replacing your originals with new ones as we do make minor changes to
them over time -- for example newer templates have a CONFIG_SITE file.
The only file you'll want to keep would be the RELEASE file.
- Andrew
D. Peter Siddons
Detector Development Group Leader
Bldg. 535B
Photon Sciences Directorate,
Brookhaven National Laboratory
Upton, NY 11973
email: [email protected]
Phone: (631) 344-2738
Re: build question Stephen Beckwith
build question D Peter Siddons
Re: build question Andrew Johnson
Re: build question D Peter Siddons
Prev: Re: build question Andrew Johnson
Next: Re: build question Stephen Beckwith
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024
ANJ, 17 Dec 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
