1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: build question
To: Andrew Johnson <[email protected]>, [email protected]
Date: Tue, 01 Apr 2014 13:33:00 -0400
Hi Andrew,
Yes, it is. I have a BSP for the uC5272 which, for complicated reasons never made it into the RTEMS tree. Eric Norum took it and modified it (and cleaned it up a lot!) for the 5282 processor version of the board. I really don't think there is anything wrong with the RTEMS side. It works well under 3.14.8.
Pete.
On 04/01/2014 01:24 PM, Andrew Johnson wrote:
Hi Peter,
On 04/01/2014 12:19 PM, D Peter Siddons wrote:
peter@peter-Latitude-E4200:~/IOCs/det_640$ make
make -C ./configure install
make[1]: Entering directory `/home/peter/IOCs/det_640/configure'
perl /usr/local/epics/base/bin/linux-x86_64/makeMakefile.pl
O.RTEMS-uC5272 ../..
mkdir O.Common
make[1]: *** No rule to make target `install.linux-x86_64', needed by
`install.RTEMS-uC5272'.  Stop.
make[1]: Leaving directory `/home/peter/IOCs/det_640/configure'
make: *** [configure.install] Error 2
so it seems to fail at the very first step, before even looking at the
src directory. GIven my history with this stuff it is almost certainly a
dumb mistake :)
Hmm, is your cross-target architecture name correct? We build for the
cross-target RTEMS-uC5282 here, not 5272.
- Andrew
D. Peter Siddons
Detector Development Group Leader
Bldg. 535B
Photon Sciences Directorate,
Brookhaven National Laboratory
Upton, NY 11973
email: [email protected]
Phone: (631) 344-2738
Re: build question Andrew Johnson
build question D Peter Siddons
Re: build question D Peter Siddons
Prev: Re: build question Andrew Johnson
Next: Re: build question Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024
ANJ, 17 Dec 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
