1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: build question
To: D Peter Siddons <[email protected]>, <[email protected]>
Date: Tue, 1 Apr 2014 09:31:36 -0500
Hi Peter,
On 04/01/2014 09:11 AM, D Peter Siddons wrote:
> I am moving an application from 3.14.8 to 3.14.12. When I try to build
> it I get immediately the following error:
> make[1]: *** No rule to make target `install.linux-x86_64', needed by
> `install.RTEMS-uC5272'.  Stop.
> THis is clearly a configuration error, but I can't put my finger on
> where things changed between these two releases. Any suggestions?
Can you show us the Makefile that is failing? GnuMake's error messages
don't always help us know what the problems are.
I would suggest using makeBaseApp.pl to create an example app and
confirm that builds properly. Then compare the first few and last few
lines of your failing Makefile with the example's equivalent. Also look
at any differences between the files in the configure directories.
HTH,
- Andrew
Advertising may be described as the science of arresting the human
intelligence long enough to get money from it. -- Stephen Leacock
Re: build question D Peter Siddons
Prev: build question D Peter Siddons
Next: Re: build question D Peter Siddons
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024
ANJ, 17 Dec 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
