Dear Christian,
I have been working recently on a similar thing. I want to use the SPI
interface of the raspberry to set some threshold values using a DAC accesible
via SPI. I used the asyn driver code to do that. If you are interrested, I can
send you the code to be included in the ioc. It uses the wiringPi library to
access the devices on the raspberryPi. Currently I have only implemented
writing values, but the reading should be easy to be implemented.
I did not yet test it with real electronics (still in production), but I would
be willing to help you get the things working.
With kind regards,
Joern Wuestenfeld
Dr. Joern Wuestenfeld
Institut für Strahlenphysik
Helmholtz-Zentrum Dresden - Rossendorf e.V
Abt. FWKH Tel: +49 351 260 3263
Postfach 510119 FAX: +49 351 260 3700
01314 Dresden eMail: [email protected]
Bautzner Landstraße 400, 01328 Dresden
Vorstand: Prof. Dr. Roland Sauerbrey, Dr. Dr. h. c. Peter Joehnk
VR 1693 beim Amtsgericht Dresden
smime.p7s
Description: S/MIME cryptographic signature
- Access to device connected RaspBerryPi SPI bus from IOC-Client Christian Pauly
Dynamic Assignment is Sequencer Ganesh Jangir
<2014>
Re: Access to device connected RaspBerryPi SPI bus from IOC-Client Dirk Zimoch
<2014>
