1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: RE: How to check if IOC is connected or not?
To: Ganesh Jangir <[email protected]>, "[email protected]" <[email protected]>
Date: Mon, 24 Mar 2014 13:51:58 +0000
The calcout record also has fields indicating the states of its input links.
record(calcout, "all_ok") {
field(INPA, "ioc1_pv")
field(INPB, "all_ok.INAV")
Tim
From: [email protected] [[email protected]] on behalf of Ganesh Jangir [[email protected]]
Sent: Monday, March 24, 2014 3:02 AM
To: [email protected]
Subject: How to check if IOC is connected or not?
Dear All,
I have multiple IOC(say 4) on 4 linux (Fedora, 64bit) machines over network. Each IOC also have running Sequencer program.
Sequencer of each  IOC need to be aware of every IOC if they are running or not/ machine connected or not, before doing some task.
How to do this?
I tried using CALC Record. Its 4 INP fields gets some particular value from four different  IOC and calculate some new value,By interpreting this value Sequencer come to know about the connected IOC.
The problem is that , in case of some disconnection of  IOC , its INP fields picking old values. And CALC record gives same value in each case.
Is this right approach for many IOCs? How to make  INP fields, to give different value in case of disconnection of some IOC.
Second, I also tried using pvConnected() function of sequencer. But it starts giving error messages incase of disconnection, before checking it.
___________________________________________________
I am using
Epics base-3.14.12.3
Sequencer seq-2.1.16
OS: Linux Fedora 19  64bit
I have following settings.
export EPICS_ROOT=/home/ganesh/epics
export EPICS_HOST_ARCH=linux-x86_64
export EPICS_BASE=$EPICS_ROOT/base-3.14.12.3
export EPICS_EXTENSIONS=$EPICS_ROOT/extensions
export EPICS_CA_ADDR_LIST="192.168.8.2 192.168.8.3 192.168.8.4 192.168.8.5"
export MOTIF_LIB=/usr/lib64/
export SEQ=$EPICS_ROOT/extensions/seq-2.1.16
export PATH=/sbin:/bin:/usr/sbin:/usr/bin:$file:$EPICS_ROOT/base-3.14.12.3/bin/linux-x86_64:/bin/linux-x86_64
export LD_LIBRARY_PATH=$LD_LIBRARY_PATH:$EPICS_BASE/lib/$EPICS_HOST_ARCH:$EPICS_EXTENSIONS/lib/$EPICS_HOST_ARCH
__________________________________________________________________
Best Regards
Ganesh
Notice: The information contained in this e-mail
message and/or attachments to it may contain
confidential or privileged information. If you are
not the intended recipient, any dissemination, use,
review, distribution, printing or copying of the
information contained in this e-mail message
and/or attachments to it are strictly prohibited. If
you have received this communication in error,
please notify us by reply e-mail or telephone and
immediately and permanently delete the message
and any attachments. Thank you
How to check if IOC is connected or not? Ganesh Jangir
Prev: How to check if IOC is connected or not? Ganesh Jangir
Next: Re: How to check if IOC is connected or not? Pearson, Matthew R.
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024
ANJ, 17 Dec 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
