Hi Andrew,
On 03/20/2014 10:11 PM, Andrew C. Starritt wrote:
> So my question is this: When I build an IOC, is there any easy way to
> only do the cross
> compilation and skip the host build? (I'm not worried about the base
> host build - it works ;).
You can't stop the build from compiling for the host architecture, but
there is another way to achieve the effect you want. You have to adjust
your Makefile so it only asks for Windows-only code to be built for the
Windows targets. That is easy to do, instead of doing
PROD += WindowsProg
you should use
PROD_WIN32 += WindowsProg
Note that WIN32 is the EPICS OSCLASS value for Windows targets. Similar
suffixes work on other variables such as SRCS, INC, LIBRARY etc. This is
all documented in the Application Developers Guide chapter 4.
http://www.aps.anl.gov/epics/base/R3-14/12-docs/AppDevGuide/node5.html
(do a search within that page for _<osclass> to find all the possible
OS-specific variables you can use).
HTH,
- Andrew
Advertising may be described as the science of arresting the human
intelligence long enough to get money from it. -- Stephen Leacock
- Cross build/compilation - target only question Andrew C. Starritt
RE: CSS BOY and 16-bit Images Gabriele Salvato
RE: using C# dll's Roehrig, Christian
<2014>
[no subject] Azra Jabeen
<2014>
