Hi everybody,
I have created a small script that perform quick conversion between V, kW and dBm in our system and I would like to apply it using internal PV however I have some infinite triggering loop problem.
Quick question: Is it possible to trigger a keyboard event? Long explanation: My idea is to have 3 input fields and when a user write a value in one of them, it change the value in the others and send the value to the corresponding PV.
The thing if that my script is correctly working If only one field get the trigger from the other otherwise it doesn't work. Below I quickly explain how my script proceed:
So when I:
I did try to check the "Skip executions triggered by PVs' first" but it doesn't apply to this case.
So If someone have an idea how I should proceed, the best way in my opinion should be to trigger only on a key action (when someone press enter) not when the value change but I have no idea if it's possible to do it.
Thanks in advance for your help Regards, --
Benoit RAT LAMY
ANJ, 17 Dec 2015 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
