Subject: |
Re: Using a Waveform record (char type representing a String) as input to an aSub record |
Andrew Johnson <[email protected]> |
To: |
Date: |
Mon, 10 Mar 2014 12:24:57 -0500 |
Hi David,
On 03/10/2014 11:27 AM, David Michel wrote:
> I'm using a Waveform record of type char to represent a string (not
> using a Stringin or Stringout record since this string has more than 40
> characters).
> That works well and I can easily put a string into this record such with
> caput -a and read it back with caget -s
You can also use the -S option (upper-case S) to caput and caget which
was added for long string support.
> Now, I need to use this string in an aSub record but I'm having
> difficulties in doing so.
> char ** myString;
> myString = (char **) precord->a;
> printf("%s\n",myString);
> The results of the printf statement shows only the first character of
> the string in ASCII.
> Any idea of I can solve this?
How is your asub.A field configured, i.e. what have you set FTA and NOA
to? They should match the waveform record, FTA=CHAR and NOA=256 or
whatever your waveform string length is.
- Andrew
Advertising may be described as the science of arresting the human
intelligence long enough to get money from it. -- Stephen Leacock
- Using a Waveform record (char type representing a String) as input to an aSub record David Michel
Re: Using a Waveform record (char type representing a String) as input to an aSub record Eric Norum
<2014>
<2014>
