1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: EPICS Archiver make error
To: [email protected]
Date: Mon, 10 Mar 2014 17:06:11 +0900
You might need many devs according to your OS distribution. For Debian Wheezy, at least you need the following : aptitude install libxmlrpc-c++4-dev libxerces-c-dev libcurl3-dev
There are many files you should fix in order to compile without any errors. Most recently, I made a very *ugly* bash script in order to reduce my burden for compiling CA classic (I am not sure classic is the right one). I did write this bash script for all purposes, so just see where you should fix many source files.
Han
#!/bin/bash
# Shell  : epics_chanarch.sh
# Author : Jeong Han Lee
# email  : [email protected]
# Date   : Tuesday, February  4 23:29:02 KST 2014
# version : 0.0.1
#    * This script may give a little room to install again-and-again
#      Classic EPICS Channel Archiver located at
#      http://sourceforge.net/projects/epicschanarch/
#      I hope it would reduce our time to concentrate real works
#      instead of painful modification of unmaintained source codes.
#   * Must install the following packages via root or sudo
#     before running this script
#     For Debian Wheezy,
#      aptitude install libxmlrpc-c++4-dev  libxerces-c-dev  libcurl3-dev
#     Of course, EPICS base, and its extension must be installed
#  - 0.0.1  Wednesday, February  5 00:47:14 KST 2014, jhlee
#           * created
# cq   : quiet
# c : continue getting a partially-downloaded file. So it allows us not to re-download an existent file
wget_options="wget -c"
# xzf  : quiet
# xzfv : verbose
tar_command="tar xzf"
make_epicschanarch()
    chanarch_dir=$1
    cd ${chanarch_dir}
    echo $PWD
    echo ""
    make_cfg="${chanarch_dir}/make.cfg"
    sed -i~ -e 's/LOCAL=\/usr\/local/LOCAL=\/usr\//g' ${make_cfg}
    # modify Tools in order to compile them correctly
    # Tuesday, February  4 18:42:16 KST 2014, jhlee
    tools_dir=${chanarch_dir}/Tools/
sed -i~ '$ a\#include <cstdio>\n#include <cstdlib>\n#include <cstdarg>' ${tools_dir}/ToolsConfig.h sed -i~ '18istatic int sort_compare(const int &a, const int &b)\n{\n return b-a;\n}\n\nstatic const char *toString(const int &i)\n{\n static char txt[10];\n sprintf(txt, "%d", i);\n return txt;\n }\n' ${tools_dir}/AVLTree.h
    sed -i~ '18,23d'  ${tools_dir}/AVLTreeTest.cpp
    sed -i '5,6d'     ${tools_dir}/AVLTreeTest.cpp
    # modify LibIO
    # error: ‘LONG_MAX’ was not declared in this scope >> BinValue.cpp
#./DataFile.h:131:5: error: ‘DataHeaderIterator’ does not name a type >> DataFile.cpp
    libIO_dir=${chanarch_dir}/LibIO/
sed -i~ '7i#include <climits>\n#include "BinChannelIterator.h"' ${libIO_dir}/BinValue.h
    # modify Storage
# ../NameHash.cpp:4:23: warning: extra tokens at end of #include directive [enabled by default]
    storage_dir=${chanarch_dir}/Storage/
    sed -i~ -e 's/.h>./.h>/g' ${storage_dir}/NameHash.cpp
    # modify XMLRPCServer
    # Cannot run or decode 'xmlrpc-c-config'
# ./main_standalone.cpp:81:101: warning: deprecated conversion from string constant to ‘char*’ [-Wwrite-strings]
    xmlrpcserver_dir=${chanarch_dir}/XMLRPCServer/
sed -i~ -e 's/1.0/1./g' ${xmlrpcserver_dir}/xmlrpc-config-wrapper sed -i~ -e 's/"archiver./(char*)"archiver./g' ${xmlrpcserver_dir}/main_standalone.cpp sed -i -e 's/"S:/(char*)"S:/g' ${xmlrpcserver_dir}/main_standalone.cpp sed -i -e 's/"A:/(char*)"A:/g' ${xmlrpcserver_dir}/main_standalone.cpp sed -i -e 's/"Get /(char*)"Get /g' ${xmlrpcserver_dir}/main_standalone.cpp
    # Engine
    # ../hammer.cpp:28:17: error: ‘stderr’ was not declared in this scope
    # ../hammer.cpp:29:58: error: ‘fprintf’ was not declared in this scope
    engine_dir=${chanarch_dir}/Engine/
sed -i~ -e 's/#include <string>/#include <cstdio>\n#include <cstdlib>\n#include <cstring>\n#include <iostream>/g' ${engine_dir}/hammer.cpp
    cd ${chanarch_dir}
    make
chanarch_name="ChannelArchiver"
EXT_SRC=${EPICS_EXTENSIONS}/src
chanarch_filename=epicschanarch.tar.gz
cd ${EPICS_EXTENSIONS}/src
echo $PWD
$wget_options -O ${chanarch_filename} http://epicschanarch.cvs.sourceforge.net/viewvc/epicschanarch/?view=tar
$tar_command ${chanarch_filename} --strip-components=1
#cd ${EXT_SRC}/${chanarch_name}
make_epicschanarch "${EXT_SRC}/${chanarch_name}"
On 03/10/2014 04:28 PM, Jack wrote:
this problem appears to be caused by the fact that the libts. is not
found in a standard library search path. Locate that one in your OS, and
fix that, or install that if that is absent.
Hope this helps,
-Mauro
Mauro Giacchini
Istituto Nazionale di Fisica Nucleare - Laboratori Nazionali di Legnaro
V.le dell'Universita', 2
35020 LEGNARO (PD) - ITALY
Tel./Fax. +39.049.8068558
EPICS _at_ LNL http://www.lnl.infn.it/~epics/
...the first EPICS installation to the project SPES realized from the
scratch in ITALY is in production since begin 2010!!
On 3/9/2014 3:22 PM, zuo.jiao wrote:
libts.a', needed
This email is free from viruses and malware because avast! Antivirus
protection is active.
http://www.avast.com
Jeong Han Lee, Dr.rer.nat.
Accelerator Systems Division
Rare Isotope Science Project
Institute for Basic Science
Daejeon, South Korea
tel  : +82-42-878-8733
fax  : +82-42-878-8799
Re: EPICS Archiver make error Ralph Lange
EPICS Archiver make error zuo.jiao
Prev: Re: EPICS Archiver make error Jack
Next: Re: EPICS Archiver make error Ralph Lange
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024
ANJ, 17 Dec 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
