And a third problem:
The set of values I need to save and restore may span multiple IOCs.
So I'm thinking Autosave is not the right tool at all.
> I know that Autosave is generally used for automatically saving the values of
> a set of database records and restoring them at boot time, but I'd like to save
> a small set of values on command, and then be able to restore them on
> command.
> I have found the create_triggered_set() function that I can run in the ioc
> startup script that assigns a database PV to trigger a save, and that seems to
> be a step in the right direction for what I want to do.
> However, a couple of problems:
> 1) There seems to be no corresponding function to assign a PV to trigger a
> restore. I suppose I can get around that by using a subroutine record to call
> fdbrestore() when it is processed.
> 2) Even if I can get around issue 1), when I run create_triggered_set() in the
> startup script at boot time, it clobbers the existing saveset. Is there a way
> around this?
> Perhaps I'm trying to use the wrong tool? Is there a better one for what I
> want to do?
- Re: Question on Autosave Pearson, Matthew R.
- RE: Question on Autosave Mooney, Tim M.
- Question on Autosave Westfall, Michael D
<2014>
<2014>
