In each IOC can you send the output of the command
epicsPrtEnvParams
From: [email protected] [[email protected]] on behalf of Ganesh Jangir [[email protected]]
Sent: Thursday, March 06, 2014 8:37 AM
To: [email protected]; [email protected]
Subject: Re: Sequencer is not monitoring Pvs from another IOC
Hi Pierrick, Benjamin
Thanks for the mail. I made an clean ioc using makeBaseApp.pl -t ioc <name> , makeBaseApp.pl -i -t ioc <name> . Added Db files and Sequencer files followed by successful make.
I am using
Epics base-3.14.12.3
Sequencer seq-2.1.16
OS: Linux Fedora 19 64bit
I am not using [X] procServ. Here is the environment variables.
#############declaring the EPICS environment LOCALLY#############################
export [X] EPICS_ROOT=/home/[X]ganesh/epics
export [X] EPICS_HOST_ARCH=[X]linux-x86_64
export [X] EPICS_BASE=$[X]EPICS_ROOT/[X]base-3.14.12.3
export [X] EPICS_EXTENSIONS=$[X]EPICS_ROOT/extensions
export [X] EPICS_CA_ADDR_LIST="192.168.8.2 192.168.8.3 192.168.8.4 192.168.8.5"
export [X] MOTIF_LIB=/[X]usr/[X]lib64/
export [X] SEQ=$[X]EPICS_ROOT/extensions/[X]seq-2.1.16
export PATH=/[X]sbin:/bin:/[X]usr/[X]sbin:/[X]usr/bin:$file:$[X]EPICS_ROOT/[X]base-3.14.12.3/bin/[X]linux-x86_64:/bin/[X]linux-x86_64
export [X] LD_LIBRARY_PATH=$[X]LD_LIBRARY_PATH:$[X]EPICS_BASE/lib/$[X]EPICS_HOST_ARCH:$[X]EPICS_EXTENSIONS/lib/$[X]EPICS_HOST_ARCH
-----[X]Pierrick [X] Hanlet wrote: -----
To: [X] Ganesh [X] Jangir <[email protected]>
Date: 03/06/2014 07:13PM
Subject: Re: [X] Sequencer is not monitoring [X] Pvs from another [X] IOC
Hi [X] Ganesh,
In order to get an answer from the experts, you will likely need to provide more information;
namely, version number of the software, the hardware configurations of the [X] IOCs, operating
system([X]s), etc. For example, one [X] IOC may be in a [X] VME crate and another [X] IOC run from a
[X]linux [X] pc; then you would have to be certain to set the environment variables correctly,
particularly [X] EPICS_CA_ADDR_LIST.
Are you running these [X] IOCs from [X] procServ? I'm asking because I have a similar issue.
Cheers,
[X]Pierrick
On 03/06/2014 01:23 PM, [X] Ganesh [X] Jangir wrote:
Dear All,
[X]Sequencer in one [X] IOC, is not able to monitor, [X] PV from another [X] IOC on the same network. However these [X] PVs are accessible by [X] caget and [X] camonitor on both machines.
[X]____Here is what I am doing.____________________________________________________
Machine 1, [X] IOC1.
[X]DB_1.db has
record(waveform, "[X]CMD_FIELD")
{ field([X]DESC, "command")
field([X]NELM, 16000)
field([X]FTVL, CHAR)
[X]SEQ1.stt
Updated above [X] PV successfully.
Machine 2 [X] IOC2
[X]SEQ2.stt has
char [X] CMD_[16000];
assign [X] CMD to "[X]CMD_FIELD";
monitor [X] CMD;
[X]evflag [X] cmdDFlag;
sync [X] CMD [X] cmdDFlag;
But not able to access the [X] PV. It works only when I am creating this [X] PV in [X] IOC2.
Please help.
Thanks and Regards
[X]Ganesh
Notice: The information contained in this e-mail
message and/or attachments to it may contain
confidential or privileged information. If you are
not the intended recipient, any dissemination, use,
review, distribution, printing or copying of the
information contained in this e-mail message
and/or attachments to it are strictly prohibited. If
you have received this communication in error,
please notify us by reply e-mail or telephone and
immediately and permanently delete the message
and any attachments. Thank you
"Whether you think you can or think you can't, either way, you are correct" -- Henry Ford
_______________________________________________________________
[X]IIT/[X]Fermilab
+44-(0)1235-44-5550 ([X]RAL)
+1-630-840-5555 ([X]FNAL)
+1-312-567-5745 ([X]IIT)
+1-630-697-8758/+44-(0)79-48-860-197 (US/UK mobile)
- Sequencer is not monitoring Pvs from another IOC Ganesh Jangir
- Re: Sequencer is not monitoring Pvs from another IOC Ganesh Jangir
Re: CSS BEAST alarm hierarchy Kasemir, Kay
Re: CSS BEAST alarm hierarchy Igor Kriznar
<2014>
RE: Sequencer is not monitoring Pvs from another IOC Ganesh Jangir
<2014>
