1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: RE: Autosave upgrade issue
To: Emmanuel Mayssat <[email protected]>, EPICS mailing list <[email protected]>
Date: Tue, 4 Mar 2014 17:53:04 +0000
Hi Emmanuel,
The config file (save_restore.cmd) didn't change between autosave 4.5 and 5.1, so you should be ok with the old one.  The format of .sav files also did not change.
Recently, though, I found out that autosave 5.0 and 5.1 do not detect and reject truncated .sav files.  (Thanks to Jon Thompson for reporting the problem.)  It's possible your trouble was caused by this error, which will be fixed in 5.2.
Tim
From: [email protected] [[email protected]] on behalf of Emmanuel Mayssat [[email protected]]
Sent: Tuesday, March 04, 2014 10:41 AM
To: EPICS mailing list
Subject: Autosave upgrade issue
I upgraded my autosave libraries on a system being commissioned. To my surprise it stopped working.
Worse, it worked partially. we quickly realized that our new BPM calibration was wrong (non default values were restored though, obviously from an older save file). We restarted the IOC then some other values where incorrect. Autosave even turned on my kicker magnet. ( i.e. this autosave upgrade could really have been a safety hazard!)
I quickly identified autosave as the most likely culprit. Indeed autosave had been upgraded just a couple of days before.
Although I could go back to what I had before, I tried to move forward. What I found is that I had upgraded from autosave 4-5 to 5-1. Then I realized that the config files which had been generated by 4-5 were being used by 5-1.
Could this be the issue?
After rebooting a few times and correcting the incorrect values, it seems that now 5-1 is working correctly.
But is it?
How to make sure that it is the case?
Should  I wipe out all of my autosave configuration and start from scratch?
Is 5-1 ready for production?
Emmanuel
Autosave upgrade issue Emmanuel Mayssat
Prev: RE: Autosave upgrade issue Mark Rivers
Next: CSS BEAST alarm hierarchy Xinyu.Wu
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024
ANJ, 17 Dec 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
