Hi Mark and Hermann-Josef,
I want to read a boolean value (DO_0) that my Rockwell PLC Micro850
publishes on ModbusTCP address 00001.
(still using the modbus module with asyn)
Now I keep getting the "cas warning: Configured TCP port was
unavailable.(...)", and read operation fails.
Anybody sees what's wrong in my setup ?
The st.cmd executed:
[root@sdiLinux iocrockTest]# ./st.cmd
#!../../bin/linux-x86/rockTest
## You may have to change rockTest to something else
## everywhere it appears in this file
< envPaths
epicsEnvSet("ARCH","linux-x86")
epicsEnvSet("IOC","iocrockTest")
epicsEnvSet("TOP","/home/sdi/Bureau/epics3.14.11/rockTest")
epicsEnvSet("EPICS_BASE","/home/sdi/Bureau/epics3.14.11/base-3-14-11")
epicsEnvSet("ASYN","/home/sdi/Bureau/epics3.14.11/modules/softs/asyn4-19")
cd /home/sdi/Bureau/epics3.14.11/rockTest
dbLoadDatabase "dbd/rockTest.dbd"
rockTest_registerRecordDeviceDriver pdbbase
drvAsynIPPortConfigure("Mirco850","134.158.42.116:502", 0, 1, 1)
modbusInterposeConfig("Mirco850", 0, 5000)
# Read the DigitalOutput DO0 at modbus adress 00001.
drvModbusAsynConfigure("modbusPort", "Mirco850", 0, 2, 00001, 1, 0,
1000, "Rockwell")
## Load record instances
#dbLoadRecords("db/xxx.db","user=sdiHost")
dbLoadRecords("db/bi_test.db","P=DO, R=0")
cd /home/sdi/Bureau/epics3.14.11/rockTest/iocBoot/iocrockTest
iocInit
Starting iocInit
## EPICS R3.14.11 $R3-14-11$ $2009/08/28 18:47:36$
## EPICS Base built Jul 23 2013
cas warning: Configured TCP port was unavailable.
cas warning: Using dynamically assigned TCP port 34829,
cas warning: but now two or more servers share the same UDP port.
cas warning: Depending on your IP kernel this server may not be
cas warning: reachable with UDP unicast (a host's IP in EPICS_CA_ADDR_LIST)
## Start any sequence programs
#seq sncxxx,"user=sdiHost"
epics> 2014/03/03 16:48:54.659 drvModbusAsyn::doModbusIO port modbusPort
is disconnected
epics>
epics> dbl
DO0
epics> dbtr DO0
ACKS: NO_ALARM ACKT: YES ASG: BKPT: 00
COSV: NO_ALARM DESC: DISA: 0 DISP: 0
DISS: NO_ALARM DISV: 1 DTYP: asynUInt32Digital
EVNT: 0 FLNK:CONSTANT 0
INP:INST_IO @asynMask(modbusPort, 0, 1, 1000)MODBUS_DATA LALM: 0
LCNT: 0 MASK: 1 MLST: 0 NAME: DO0
NSEV: NO_ALARM NSTA: NO_ALARM ONAM: 1 ORAW: 0
OSV: MINOR PACT: 0 PHAS: 0 PINI: NO
PRIO: LOW PROC: 0 PUTF: 0 RPRO: 0
RVAL: 0 SCAN: 1 second SDIS:CONSTANT SEVR: NO_ALARM
SIML:CONSTANT SIMM: NO SIMS: NO_ALARM SIOL:CONSTANT
STAT: NO_ALARM SVAL: 0 TIME: 2014-03-03 17:14:57.906900018
TPRO: 0 TSE: 0 TSEL:CONSTANT UDF: 0
VAL: 0 ZNAM: 0 ZSV: NO_ALARM
epics>
The bi_test.db I made, copy of bi_bit.template:
# bi record template for register inputs
record(bi,"$(P)$(R)") {
field(DTYP,"asynUInt32Digital")
field(INP,"@asynMask(modbusPort, 0, 1, 1000) MODBUS_DATA")
field(SCAN,"1 second")
field(ZNAM,"0")
field(ONAM,"1")
field(ZSV,"0")
field(OSV,"1")
Yours sincerely
Rémi FAURE
Assistant Engineer at Detectors and Instrumentation Department
LPSC Grenoble
53 av des Martyrs
38026 Grenoble Cedex
FRANCE
tel 33 (0)4 76 28 41 21
fax 33 (0)4 76 28 41 84
E-mail:[email protected]
Le 17/02/2014 13:34, Mark Rivers a écrit :
Hi Rémi,
Are you using the EPICS "modbus" module? It can be found here:
http://cars.uchicago.edu/software/epics/modbus.html
That has examples of how to build an IOC application, and has a test iocBoot directory to demonstrate it.
Basically your IOC xxxInclude.dbd file needs this line:
include "modbusSupport.dbd"
and your IOC Makefile needs this line:
PROD_LIBS += modbus
If you are using the "modbus" module and still have questions please let me know.
From:[email protected] [[email protected]] on behalf of faure [[email protected]]
Sent: Monday, February 17, 2014 3:05 AM
To:[email protected]
Subject: EPICS/ModbusTCP communication with Rockwell Micro 850 PLC
I want to create an EPICS IOC to communicate with a Rockwell Micro 850
PLC via Modbus TCP, but I'm stuck at the start of the process.
Which template of MakeSupport.pl is recommended for Modbus TCP?
Where can I find "how to" document for Modbus TCP communication? It
helped myself perfectly for my firsts Serial and GPIB tries.
Thank you in advance.
Yours sincerely
Rémi FAURE
LPSC Grenoble
53 av des Martyrs
FRANCE
- RE: EPICS/ModbusTCP communication with Rockwell Micro 850 PLC Mark Rivers
- EPICS/ModbusTCP communication with Rockwell Micro 850 PLC faure
Re: EPICS base-3.14.12.4 make Error Andrew Johnson
<2014>
<2014>
