1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Autosave an array field (not record)
Date: Thu, 27 Feb 2014 11:49:27 -0800
Is there a way to do this?  Do I have to use a waveform record and feed the waveform
to the desired field (of another record)?
In my request file, I have this array field in the same way like any other scaler field.
However in the auto-generated .sav file, the filed IS commented out with "#", with "Connected"
after the name of the field, but no values at all (nothing like the @array@ { ...).
Please advice.  Thank you very much.
Dehong
RE: Autosave an array field (not record) Mooney, Tim M.
Prev: Re: newline in IOCSH_PS1 value Mark Davis
Next: RE: Autosave an array field (not record) Mooney, Tim M.
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: newline in IOCSH_PS1 value Andrew Johnson
ANJ, 17 Dec 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
