1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: newline in IOCSH_PS1 value
To: <[email protected]>, <[email protected]>
Date: Thu, 27 Feb 2014 11:07:11 -0600
Hi Mark D,
On 02/27/2014 10:05 AM, Mark Davis wrote:
> But epicsEnvShow definitely doesn't show all the same values that my
> bash shell (the same one used to launch the IOC shell) shows.
You are running the IOC as root, so of course it won't inherit the
environment variables from your personal account:
> Here is the list of environment variables from my bash shell
> USER=epics
> And here is what the IOC shell shows:
> USER=root
Whatever wrapper you are using to run the IOC is replacing your personal
environment with root's (which is a good thing from a security
perspective, you don't want a user's LD_PRELOAD value to leak into a
root process for example).
- Andrew
Advertising may be described as the science of arresting the human
intelligence long enough to get money from it. -- Stephen Leacock
newline in IOCSH_PS1 value Mark Davis
Re: newline in IOCSH_PS1 value Eric Norum
Re: newline in IOCSH_PS1 value Mark Davis
RE: newline in IOCSH_PS1 value Mark Rivers
Prev: Re: newline in IOCSH_PS1 value Eric Norum
Next: Re: newline in IOCSH_PS1 value Mark Davis
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: newline in IOCSH_PS1 value Mark Davis
Next: Autosave an array field (not record) Zhang, Dehong
ANJ, 17 Dec 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
