1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: RE: Store long strings in EPICS record.
To: "'David Michel'" <[email protected]>, "[email protected]" <[email protected]>
Date: Tue, 25 Feb 2014 19:49:58 +0000
The path can be set in many ways.  It can be set via a Channel Access put from any CA client.  For example, it could be entered from a normal medm text entry widget, etc.
In this case the user entered the components of the file path (path, file name, file number, C-style format string to construct file name from the preceding values) in medm and the IOC driver constructed the full path string, which is what I showed in my previous post.  The IOC driver set that value in a waveform record, via callbacks.  That record has SCAN=I/O Intr so it updates when the driver changes it.
Sent: Tuesday, February 25, 2014 11:37 AM
To: Mark Rivers; [email protected]
Hi Mark,
In your example, looks like you're using a filepath. I'm confused as to where you specify that path in the waveform record in the first place?
David
You cannot store a long string in a stringin record.
However, you can store a long string in a waveform record with FTVL=CHAR.  caget, medm and other clients know how to display this correctly.
Here is an example:
corvette:~>cainfo GSE-PIL1:cam1:FullFileName_RBV
    State:            connected
    Host:             164.54.160.161:5064
    Access:           read, write
    Native data type: DBF_CHAR
    Request type:     DBR_CHAR
    Element count:    256
corvette:~>caget -S GSE-PIL1:cam1:FullFileName_RBV
GSE-PIL1:cam1:FullFileName_RBV /cars5/Data/gpd_user/data/idc/2014/run1/eng/testing/images/testing_1/S045/stubbs_test_1002.tif
RE: Store long strings in EPICS record. David Michel
Prev: RE: Waveform record I/O interrupt. asyn Hill, Jeff
Next: Re: Monitoring whether an IP device is connected or not Dohn Arms
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: RE: Store long strings in EPICS record. David Michel
Next: Monitoring whether an IP device is connected or not David Michel
ANJ, 17 Dec 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
