Thank you Vishnu From: Mark Rivers <[email protected]> Sent: Sun, 23 Feb 2014 02:31:26 To: Vishnu Patel <[email protected]> Cc: techtalk <[email protected]> Subject: Re: Waveform record I/O interrupt. asyn If your driver can have new values every 50 nanoseconds, and can do that continuously, then there is no way that EPICS record processing can keep up. You need to rethink your approach. ________________________________ From: [email protected] [[email protected]] Sent: Saturday, February 22, 2014 2:28 PM To: Mark Rivers Cc: techtalk Subject: Re: Waveform record I/O interrupt. asyn In my case the drive can have new value at maximum 50ns fast. Presently, i am testing 2 consecutive interrupts. But that may be continuous or burst. Thanks Vishnu From: Mark Rivers <[email protected]> Sent: Sat, 22 Feb 2014 20:21:00 To: Vishnu Patel <[email protected]>, "techtalk " <[email protected]> Subject: Re: Waveform record I/O interrupt. asyn > In devAsynXXXArray.c dbScanUnlock has been used before scanIoRequest(). Can it create problem for repeating same value? No, it does not matter the order there. scanIoRequest just queues a request to process the record later in a callback thread. > My assumption is as dbScanUnlock and before scanIoRequest() execute, value change and second time triggers interrupt. This result same value for both interrupts. The problem is that your driver does a second callback after the first callback has called scanIoRequest but before the callback thread has processed the record. > I checked interrupt callback code in devAsynInt32.c where epicsMutexUnlock has been used after scanIoRequest(). That does not matter. In devAsynInt32 that is a private mutex, so the callback does not call dbScanLock(). That mutex protects the ring buffer so that 2 threads are not accessing the ring buffer at the same time. In devAsynInt32 if another driver callback occurs before the record processes then the new value is placed in the ring buffer. This can handle the situation of short bursts where the driver callbacks happen faster than record processing. But if the driver callbacks continue to happen faster than record processing, then the ring buffer will overflow and some values will be dropped. This is much harder to handle with arrays because it may involve allocating and copying large amounts of data in order to buffer it. You said your driver can produce new values that are only 1 microsecond apart. Does it do this continuously, or only in short bursts? If short bursts, then how many rapid callbacks in a burst? Are your arrays only 3 elements long in the real application, or was that just for testing? Mark ________________________________ From: [email protected] [[email protected]] on behalf of Vishnu Patel [[email protected]] Sent: Friday, February 21, 2014 12:35 PM To: techtalk Subject: Waveform record I/O interrupt. asyn Hello, I am facing problem in I/O Interrupt for waveform record in the asyn. If the value of waveform record change very fast then some of the samples missing or same sample repeat twice even if before p_interruptInt32Array->callback () function the value is scanned properly by driver. But i think the read value is pushed to the callback but it is not handle that much fast in the callback. I checked the code for interruptCallbackInput in devAsynXXXArray.h. In devAsynXXXArray.c dbScanUnlock has been used before scanIoRequest(). Can it create problem for repeating same value? My assumption is as dbScanUnlock and before scanIoRequest() execute, value change and second time triggers interrupt. This result same value for both interrupts. I checked interrupt callback code in devAsynInt32.c where epicsMutexUnlock has been used after scanIoRequest(). Thank you Vishnu [http://sigads.rediff.com/RealMedia/ads/adstream_nx.ads/www.rediffmail.com/signatureline.htm@Middle]<http://sigads.rediff.com/RealMedia/ads/click_nx.ads/www.rediffmail.com/signatureline.htm@Middle?> Get your own FREE website, FREE domain & FREE mobile app with Company email. Know More ><http://track.rediff.com/click?url=""> [http://sigads.rediff.com/RealMedia/ads/adstream_nx.ads/www.rediffmail.com/signatureline.htm@Middle]<http://sigads.rediff.com/RealMedia/ads/click_nx.ads/www.rediffmail.com/signatureline.htm@Middle?> Get your own FREE website, FREE domain & FREE mobile app with Company email. Know More ><http://track.rediff.com/click?url="">
ANJ, 17 Dec 2015 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
