Hi Everyone,
I am having trouble figuring out whats causing this strange error I am encountering on one of my EPICS servers. (another server with similar versions of everything does not have this error). I am using the latest versions of asyn (4-22) and motor (6-8). I have made all modifications listed such that motor record builds its example application, including WithAsyn which is what I really need.
Now when I try and run an IOC with an included st.cmd file (with all relevant substitions made such as variable names made and the location of my motor) I receive errors that the commands are not found-
../../bin/linux-x86_64/WithAsyn st.cmd.AG_CONEX
#errlogInit(5000)
< envPaths
epicsEnvSet("ARCH","linux-x86_64")
epicsEnvSet("IOC","iocWithAsyn")
epicsEnvSet("TOP","/home/ipsuser/epics/support/motorR6-8")
epicsEnvSet("MOTOR","/home/ipsuser/epics/support/motorR6-8")
epicsEnvSet("SSCAN","/home/ipsuser/epics/support/sscan-2-9")
epicsEnvSet("ASYN","/home/ipsuser/epics/support/asyn4-22")
# Tell EPICS all about the record types, device-support modules, drivers,
# etc.
dbLoadDatabase("../../dbd/WithAsyn.dbd")
WithAsyn_registerRecordDeviceDriver(pdbbase)
### Motors
dbLoadTemplate "motor.substitutions.AG_CONEX"
# For Windows
#drvAsynSerialPortConfigure("serial1", "COM3", 0, 0, 0)
# For Linux
drvAsynSerialPortConfigure("serial1", "/dev/stages/cc", 0, 0, 0)
asynSetOption("serial1",0,"baud","921600")
st.cmd.AG_CONEX -- Line 15 -- Command asynSetOption not found.
asynSetOption("serial1",0,"bits","8")
st.cmd.AG_CONEX -- Line 16 -- Command asynSetOption not found.
asynSetOption("serial1",0,"stop","1")
st.cmd.AG_CONEX -- Line 17 -- Command asynSetOption not found.
asynSetOption("serial1",0,"parity","none")
st.cmd.AG_CONEX -- Line 18 -- Command asynSetOption not found.
asynSetOption("serial1",0,"clocal","Y")
st.cmd.AG_CONEX -- Line 19 -- Command asynSetOption not found.
asynSetOption("serial1",0,"crtscts","N")
st.cmd.AG_CONEX -- Line 20 -- Command asynSetOption not found.
asynOctetSetInputEos("serial1",0,"\r\n")
st.cmd.AG_CONEX -- Line 22 -- Command asynOctetSetInputEos not found.
asynOctetSetOutputEos("serial1",0,"\r\n")
st.cmd.AG_CONEX -- Line 23 -- Command asynOctetSetOutputEos not found.
asynSetTraceIOMask("serial1", 0, 2)
st.cmd.AG_CONEX -- Line 25 -- Command asynSetTraceIOMask not found.
#asynSetTraceMask("serial1", 0, 9)
# Load asyn record
dbLoadRecords("/home/ipsuser/epics/support/asyn4-22/db/asynRecord.db", "P=dell:,R=serial1,PORT=serial1, ADDR=0,OMAX=256,IMAX=256")
Record "dell:serial1" is of unknown type "asyn" - Error at or before ")" in file "/home/ipsuser/epics/support/asyn4-22/db/asynRecord.db" line 1
I feel like I have exhausted any ideas I have about what may be causing this, so any help will be appreciated.
Andrew Gomella
RE: control knobs to a new control system Emmanuel Mayssat
RE: Asyn commands not found in Motor record WithAsyn example? Gomella, Andrew (NIH/NHLBI) [F]
<2014>
Re: Fwd: epics base with MinGW-w64 Andrew Johnson
<2014>
