1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: RE: control knobs to a new control system
To: [email protected], [email protected]
Date: Tue, 18 Feb 2014 18:34:54 +0100
Hi Mauro,
at PSI we use a "knob-box", where you can assign an EPICS PV to a physical wheel. Four of this wheels are in one box. A touch screen above these wheels show the actual value of the PV and allows you to control the step size of the wheel, set the former set-point (old value), or to type a numeric value to a device.
Unfortunately the box is an in-house design, you cannot buy it off-the-shelf. Rob Emery's solution sounds more promising for you.
A knob-box is very nice if you want to fine tune a couple of devices simultaneously without looking at the screen or the keyboard. But I agree with Emmanuel that you can achieve the same thing with keyboard control. MEDM or QtDM supports in addition to sliders the so calls "wheelswitch". In QtDM this can be controlled by the keyboard, as well as a slider can. It may needs a little bid of initial effort to create key-bindings that work for you, since switching from one device to the other is not yet supported. But it is maybe less effort then the long term support of the control knobs hardware.
Cheers
Andreas
Prev: Re: Vme support in devLib for Linux Michael Davidsaver
Next: RE: control knobs to a new control system Emmanuel Mayssat
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: VS: control knobs to a new control system Koponen Jukka
Next: RE: areaDetector driver for Point Grey FlyCapture2 SDK? Mark Rivers
ANJ, 17 Dec 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
