1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: RE: record processing time
To: "'[email protected]'" <[email protected]>
Cc: techtalk <[email protected]>
Date: Fri, 14 Feb 2014 15:14:35 +0000
Hi Vishnu,
Please tell us about your output records, TEST:OUT0-O, etc.  Are they connected to hardware?  If so, is the device support synchronous or asynchronous, and what driver are you using?  If they are connected to hardware and the device support is synchronous, then 50 microseconds may just be the time it takes the driver to do the I/O.  If the records are not connected to hardware then how did you measure the 50 microseconds?
Sent: Friday, February 14, 2014 8:37 AM
To: Mark Rivers
Cc: techtalk
Subject: Re: record processing time
   In my application i am putting value on 4 output port lines simultaneously with dfanout record.
record (dfanout,"TEST:EVENT1-FOUT")
        field(DESC, "stop all event simaltanously")
        field(DOL, "TEST:WAIT-EVENT")
        field(HOPR, "1")
        field(LOPR, "0")
        field(OMSL, "closed_loop")
        field(OUTA, "TEST:OUT0-O PP")
        field(OUTB, "TEST:OUT1-O PP")
        field(OUTC, "TEST:OUT2-O PP")
        field(OUTD, "TEST:OUT3-O PP")
  "TEST:OUT0-O,    TEST:OUT1-O,   TEST:OUT2-O, and TEST:OUT3-O  are 4 output record putting the values on output port lines.
The TEST:WAIT-EVENT is the taking value from User interface. 0 or 1.
I observed the delay between each output is approximately 50 micro second. so total delay from first to last PV is ~200 micro second.
The OS running the IOC is RHEL.
I would like to know this delay time is normal in EPICS or i can even get better with some mechanism.
Thank you
Sent: Wed, 12 Feb 2014 20:39:16
To: Vishnu Patel <[email protected]>, "techtalk " <[email protected]>
The processing time depends of course on the record type and the CPU you are using.  But it is typically on the order of a few microseconds.
From: [email protected] [[email protected]] on behalf of Vishnu Patel [[email protected]]
Sent: Wednesday, February 12, 2014 8:16 AM
To: techtalk
Subject: record processing time
  I would like to know about time required for record processing.
In my application
When PV1 becomes 1  (scan I/O Intr.),  process waveform record with FLNK and  then first element value of waveform record is placed in PVx and second element value of waveform record is put in PVy with subArray record.
I would like to know, what is the process time of EPICS record processing?
Thank you
Vishnu
[http://sigads.rediff.com/RealMedia/ads/adstream_nx.ads/www.rediffmail.com/signatureline.htm@Middle]<http://sigads.rediff.com/RealMedia/ads/click_nx.ads/www.rediffmail.com/signatureline.htm@Middle?>
Get your own FREE website, FREE domain & FREE mobile app with Company email.
       Know More ><http://track.rediff.com/click?url="">>
Know More >
Re: record processing time Vishnu Patel
Prev: Re: record processing time Vishnu Patel
Next: Re: MSI macro setting in substitutions file Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Next: Re: record processing time Vishnu Patel
ANJ, 17 Dec 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
