1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: CSS Archiving - non RDB PV
To: <[email protected]>
Date: Thu, 13 Feb 2014 13:36:55 +0200
Hi
I'm using CSS and can successfully use archiving for my PV I'm using. (without using any RDB)
By using the 'Data Browser Plot' and adding my PV, I can track my samples quite ok.
My problem is that when I setup designated start/end times, it archives this time fine, but I need to know how to recall this
archive in CSS.
With this recalled archive, I'm hoping to use 'Inspect Waveform' to see the history.
Currently I save my 'Data Browser Plot' to a file, say ('anyfile.plt').
When I display this file in my 'Data Browser' and select 'Inspect Waveform', I then have to select a PV from 'Select item for sample
inspection'. Doing this gives me the current waveforms....
I'm using CSS 3.2.14  (64-bit Windows 7)
Thanks
Amien
Mogamad Amien Crombie
NRF : iThemba LABS
EIT Group
Laboratory for Accelerator Based Sciences
Somerset West, Western Cape
South Africa
<<attachment: winmail.dat>>
Prev: Re: Query on TCP IP RITU JAIN
Next: RE: Query on TCP IP Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: RE: Query on TCP IP Emmanuel Mayssat
Next: Binary record that recover its value after changed Antonio Borondo
ANJ, 17 Dec 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
