On 12.02.2014 14:28, Mark Rivers wrote:
You can do that with a Channel Access link. The exact syntax depends on the record type, but something like the following:
record (ai, "MyLocalRecord") {
field(INP, "MyRemoteRecord CP MS")
This will make the value of MyLocalRecord be fetched from MyRemoteRecord every time MyRemoteRecord posts a channel access monitor.
If you do not specify the type of your link, e.g.,
record (ao, "MyRecord") {
field(OUT, "MyOtherRecord")
EPICS will determine the link type at boot time.
If the target record is found on the same host, that link will be a
database link, otherwise the IOC will try to resolve it remotely (using
Channel Access).
Cheers,
~Ralph
- Re: Channel Access Link Kasemir, Kay
- Channel Access Link Antonio Borondo
- RE: Channel Access Link Mark Rivers
RE: Channel Access Link Antonio Borondo
record processing time Vishnu Patel
<2014>
<2014>
