1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: WG: Re: motorRecord on linux-arm
To: [email protected]
Date: Fri, 7 Feb 2014 18:02:33 +0100
Am 07.02.2014 16:56, schrieb Ron Sluiter:
> On 2/7/2014 9:21 AM, [email protected] wrote:
>> I suggest to remove the switch and replace the occurrence of  MSB_First
with the EPICS provided endianness switch:
>> +#include <epicsEndian.h>
>> -#ifdef MSB_First
>> +#if (EPICS_BYTE_ORDER == EPICS_ENDIAN_BIG)
> Thanks for the suggestion but MSB_First/LSB_First is set to indicate how
C/C++ bit fields are packed, not endianness.
> What compiler and compiler version are you using?
I verified with the following compilers:
Linux 32bit/64bit (gcc4.7.4)
linux arm gcc-Version 4.7.2 20120731 (prerelease) (crosstool-NG
linaro-1.13.1+bzr2458 - Linaro GCC 2012.08)
powerpc-rtems4.10.2 (mvme2100 cpu=603e)
tornado-2.2 (CPU=MC68040)
At least for gcc bit field packing is LSB_first for little endian and
MSB_first for big endian machines.
If you are afraid of breaking existing code, how about this:
#if defined(_WIN32) || defined(_M_IX86) || defined(_X86_)
     #define LSB_First (TRUE)  /* LSB is packed first. */
#elif defined(__i386__) || defined(_armv4l_) || defined(_X86_64_) ||
defined(__APPLE__)
#elif defined(i386)
#elif defined(sparc) || defined(m68k) || defined(powerpc)
     #define MSB_First (TRUE)  /* MSB is packed first. */
#elif defined(ppc603e)
#elif defined(CPU) && ((CPU == PPC604) || (CPU == PPC603) || (CPU ==
PPC85XX) || (CPU == MC68040) || (CPU == PPC32))
#elif defined(__GNUC__)
     #if (EPICS_BYTE_ORDER == EPICS_ENDIAN_LITTLE)
     #else
     #endif
#else
     #error: unknown bit order!
#endif
Jens
Re: WG: Re: motorRecord on linux-arm Torsten Bögershausen
Prev: RE: asyn driver problem running Linux 3.8.13 with arm processor Jim Chen
Next: Re: asyn driver problem running Linux 3.8.13 with arm processor Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: motorRecord on linux-arm Till Straumann
Next: Re: WG: Re: motorRecord on linux-arm Torsten Bögershausen
ANJ, 17 Dec 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
